Datasheet Wago 891-8995/105-503 — Даташит
Соединительный кабель; Розетка - свободный конец; 5-пол.; Кодирование B; длиной 5 м; с изоляцией из ПВХ
| 891-8995/105-207 Wago | по запросу | ||
| Coding | B |
| Цвет | gray |
| Color of sheathed cable | gray |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 7.8 … 9.3 mm |
| GTIN | 4055143517614 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | 1 2 3 4 5 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Number of Poles | 5 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | 1 2 3 4 5 |
| Printing color of mating face | black |
| Printing color of sheathed cable | black |
| Printing color of strain relief | white |
| Rated current | 10 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 38 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 5 m |
| Total number of potentials | 5 |
| Type of cable | Control line 5 x 1 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 570.433 г |
Серия: 891 (100 из 1377)
- 891-8995/006-405 891-8995/006-407 891-8995/006-501 891-8995/006-502 891-8995/006-503 891-8995/006-505 891-8995/006-507 891-8995/006-601 891-8995/006-602 891-8995/006-603 891-8995/006-605 891-8995/006-607 891-8995/006-701 891-8995/006-702 891-8995/006-703 891-8995/006-705 891-8995/006-707 891-8995/006-801 891-8995/006-802 891-8995/006-803 891-8995/006-805 891-8995/006-807 891-8995/016-101 891-8995/016-102 891-8995/016-201 891-8995/016-202 891-8995/016-301 891-8995/016-302 891-8995/016-401 891-8995/016-402 891-8995/016-501 891-8995/016-502 891-8995/016-601 891-8995/016-602 891-8995/016-701 891-8995/016-702 891-8995/016-801 891-8995/016-802 891-8995/105-103 891-8995/105-105 891-8995/105-107 891-8995/105-203 891-8995/105-205 891-8995/105-207 891-8995/105-303 891-8995/105-305 891-8995/105-307 891-8995/105-403 891-8995/105-405 891-8995/105-407 891-8995/105-503 891-8995/105-505 891-8995/105-507 891-8995/105-603 891-8995/105-605 891-8995/105-607 891-8995/105-703 891-8995/105-705 891-8995/105-707 891-8995/105-803 891-8995/105-805 891-8995/105-807 891-8995/106-101 891-8995/106-102 891-8995/106-103 891-8995/106-105 891-8995/106-107 891-8995/106-201 891-8995/106-202 891-8995/106-203 891-8995/106-205 891-8995/106-207 891-8995/106-301 891-8995/106-302 891-8995/106-303 891-8995/106-305 891-8995/106-307 891-8995/106-401 891-8995/106-402 891-8995/106-403 891-8995/106-405 891-8995/106-407 891-8995/106-501 891-8995/106-502 891-8995/106-503 891-8995/106-505 891-8995/106-507 891-8995/106-601 891-8995/106-602 891-8995/106-603 891-8995/106-605 891-8995/106-607 891-8995/106-701 891-8995/106-702 891-8995/106-703 891-8995/106-705 891-8995/106-707 891-8995/106-801 891-8995/106-802 891-8995/106-803
8918995/105503, 891 8995/105 503
