Datasheet Wago 891-8995/106-501 — Даташит
Соединительный кабель; Розетка - свободный конец; 5-пол.; длиной 5 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
| 891-8995/106-803 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | PL |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| Fire load | 14.132 MJ |
| GTIN | 4055143386647 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 1 2 3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ 1 2 3 |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 13 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 45 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 5 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 832.577 г |
Серия: 891 (100 из 1377)
- 891-8995/016-601 891-8995/016-602 891-8995/016-701 891-8995/016-702 891-8995/016-801 891-8995/016-802 891-8995/105-103 891-8995/105-105 891-8995/105-107 891-8995/105-203 891-8995/105-205 891-8995/105-207 891-8995/105-303 891-8995/105-305 891-8995/105-307 891-8995/105-403 891-8995/105-405 891-8995/105-407 891-8995/105-503 891-8995/105-505 891-8995/105-507 891-8995/105-603 891-8995/105-605 891-8995/105-607 891-8995/105-703 891-8995/105-705 891-8995/105-707 891-8995/105-803 891-8995/105-805 891-8995/105-807 891-8995/106-101 891-8995/106-102 891-8995/106-103 891-8995/106-105 891-8995/106-107 891-8995/106-201 891-8995/106-202 891-8995/106-203 891-8995/106-205 891-8995/106-207 891-8995/106-301 891-8995/106-302 891-8995/106-303 891-8995/106-305 891-8995/106-307 891-8995/106-401 891-8995/106-402 891-8995/106-403 891-8995/106-405 891-8995/106-407 891-8995/106-501 891-8995/106-502 891-8995/106-503 891-8995/106-505 891-8995/106-507 891-8995/106-601 891-8995/106-602 891-8995/106-603 891-8995/106-605 891-8995/106-607 891-8995/106-701 891-8995/106-702 891-8995/106-703 891-8995/106-705 891-8995/106-707 891-8995/106-801 891-8995/106-802 891-8995/106-803 891-8995/106-805 891-8995/106-807 891-8995/116-101 891-8995/116-102 891-8995/116-201 891-8995/116-202 891-8995/116-301 891-8995/116-302 891-8995/116-401 891-8995/116-402 891-8995/116-501 891-8995/116-502 891-8995/116-601 891-8995/116-602 891-8995/116-701 891-8995/116-702 891-8995/116-801 891-8995/116-802 891-8995/205-103 891-8995/205-105 891-8995/205-107 891-8995/205-203 891-8995/205-205 891-8995/205-207 891-8995/205-303 891-8995/205-305 891-8995/205-307 891-8995/205-403 891-8995/205-405 891-8995/205-407 891-8995/205-503 891-8995/205-505
8918995/106501, 891 8995/106 501
