Datasheet Wago 891-8995/206-301 — Даташит
Соединительный кабель; Штекер - свободный конец; 5-пол.; длиной 3 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
| 891-8995/206-403 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | PL |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 9.3 … 11.6 mm |
| Fire load | 8.59 MJ |
| GTIN | 4055143386685 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 1 2 3 |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 4.4 mm (0.173 inch) |
| Potential marking | N ⏚ 1 2 3 |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 13 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 45 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 3 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 486 г |
Серия: 891 (100 из 1377)
- 891-8995/106-802 891-8995/106-803 891-8995/106-805 891-8995/106-807 891-8995/116-101 891-8995/116-102 891-8995/116-201 891-8995/116-202 891-8995/116-301 891-8995/116-302 891-8995/116-401 891-8995/116-402 891-8995/116-501 891-8995/116-502 891-8995/116-601 891-8995/116-602 891-8995/116-701 891-8995/116-702 891-8995/116-801 891-8995/116-802 891-8995/205-103 891-8995/205-105 891-8995/205-107 891-8995/205-203 891-8995/205-205 891-8995/205-207 891-8995/205-303 891-8995/205-305 891-8995/205-307 891-8995/205-403 891-8995/205-405 891-8995/205-407 891-8995/205-503 891-8995/205-505 891-8995/205-507 891-8995/205-603 891-8995/205-605 891-8995/205-607 891-8995/205-703 891-8995/205-705 891-8995/205-707 891-8995/205-803 891-8995/205-805 891-8995/205-807 891-8995/206-101 891-8995/206-102 891-8995/206-103 891-8995/206-105 891-8995/206-107 891-8995/206-201 891-8995/206-202 891-8995/206-203 891-8995/206-205 891-8995/206-207 891-8995/206-301 891-8995/206-302 891-8995/206-303 891-8995/206-305 891-8995/206-307 891-8995/206-401 891-8995/206-402 891-8995/206-403 891-8995/206-405 891-8995/206-407 891-8995/206-501 891-8995/206-502 891-8995/206-503 891-8995/206-505 891-8995/206-507 891-8995/206-601 891-8995/206-602 891-8995/206-603 891-8995/206-605 891-8995/206-607 891-8995/206-701 891-8995/206-702 891-8995/206-703 891-8995/206-705 891-8995/206-707 891-8995/206-801 891-8995/206-802 891-8995/206-803 891-8995/206-805 891-8995/206-807 891-8995/216-101 891-8995/216-102 891-8995/216-201 891-8995/216-202 891-8995/216-301 891-8995/216-302 891-8995/216-401 891-8995/216-402 891-8995/216-501 891-8995/216-502 891-8995/216-601 891-8995/216-602 891-8995/216-701 891-8995/216-702 891-8995/216-801 891-8995/216-802
8918995/206301, 891 8995/206 301
