Datasheet Wago 896 — Даташит
Серия896
Datasheet Wago 896
Wago 896
Parameters / Models896-231
896-231
896-232
896-232
896-233
896-233
896-234
896-234
Actuation typeOperating toolOperating tool
CodingAA
Цветgraygrayblackwhite
Connection technologyScrew clamp connectionScrew clamp connection
Connection technology 2IDC connectionIDC connection
Contact materialCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treated
Country of originCHCHDEDE
Cross section of single conductor, mm²2.52.5
Degree of protectionIP20IP20IP20IP20
Габариты: глубина55 mm / 2.165 inch90 mm / 3.543 inch
Durchmesser der Mantelleitung9.2 … 11.4 mm9.2 … 11.4 mm
Fire load, MJ0.8641.52.7672.77
Flammability class per UL94V0V0V0V0
GTIN4045454004194404545400421740454540042794045454154639
Ground functionwith preceding GND contactwith preceding GND contact
Height33 mm / 1.299 inch34 mm / 1.339 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Locking of plug-in connectionlocking leverlocking lever
MarkingL ⏚ NL ⏚ N
Mating force of a plug-in connectionapprox. 30–70N (depending on number of poles)approx. 30–70N (depending on number of poles)approx. 30 … 70 N (depending on pole number)approx. 30 … 70 N (depending on pole number)
Mismating protectionYesYesYesYes
Product Group20 (WINSTA)20 (WINSTA)20 (WINSTA)20 (WINSTA)
Rated current, A2424
Rated impulse voltage (III / 3), kV44
Rated voltage (III / 3), В250250
Reaction to fire class per EN 50575EcaEca
Retention force of a plug-in connectionwhen locked: > 80Nwhen locked: > 80N
Surrounding air (operating) temperature-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C
Total length, m0.440.44
Total number of connection points33
Total number of potentials33
Unmating force of a plug-in connectionwhen unlocked: approx. 15–20Nwhen unlocked: approx. 15–20Nwhen unlocked: approx. 30 … 70 N (depending on pole number)when unlocked: approx. 30 … 70 N (depending on pole number)
Вес, г4590161.356161.279
Ширина33 mm / 1.299 inch30 mm / 1.181 inch
Серия: 896 (4)
На английском языке: Datasheet Wago 896
