Datasheet Wago 899 — Даташит
Серия899
Datasheet Wago 899
Parameters / Models899-631
899-631
899-631/100-000
899-631/100-000
899-631/104-000
899-631/104-000
899-631/105-000
899-631/105-000
899-631/123-000
899-631/123-000
899-631/130-000
899-631/130-000
899-631/140-000
899-631/140-000
899-631/149-000
899-631/149-000
899-631/180-000
899-631/180-000
899-631/181-000
899-631/181-000
899-631/186-000
899-631/186-000
899-631/187-000
899-631/187-000
899-631/189-000
899-631/189-000
899-631/302-000
899-631/302-000
899-631/304-000
899-631/304-000
899-631/305-000
899-631/305-000
899-631/308-000
899-631/308-000
899-631/309-000
899-631/309-000
899-631/310-000
899-631/310-000
899-631/311-000
899-631/311-000
899-631/312-000
899-631/312-000
899-631/313-000
899-631/313-000
899-631/315-000
899-631/315-000
899-631/319-000
899-631/319-000
899-631/327-000
899-631/327-000
899-631/330-000
899-631/330-000
899-631/331-000
899-631/331-000
899-631/334-000
899-631/334-000
899-631/338-000
899-631/338-000
899-631/339-000
899-631/339-000
899-631/341-000
899-631/341-000
899-631/346-000
899-631/346-000
899-631/349-000
899-631/349-000
899-631/350-000
899-631/350-000
899-631/354-000
899-631/354-000
899-631/363-000
899-631/363-000
899-631/374-000
899-631/374-000
899-631/386-000
899-631/386-000
899-631/395-000
899-631/395-000
899-631/405-000
899-631/405-000
899-631/421-000
899-631/421-000
899-631/442-000
899-631/442-000
899-631/443-000
899-631/443-000
899-631/444-000
899-631/444-000
899-631/450-000
899-631/450-000
899-631/453-000
899-631/453-000
899-631/454-000
899-631/454-000
899-631/455-000
899-631/455-000
899-632
899-632
899-632/101-000
899-632/101-000
899-632/138-000
899-632/138-000
899-632/182-000
899-632/182-000
899-632/199-000
899-632/199-000
899-681
899-681
899-681/100-000
899-681/100-000
899-681/104-000
899-681/104-000
899-681/105-000
899-681/105-000
899-681/123-000
899-681/123-000
899-681/129-000
899-681/129-000
899-681/142-000
899-681/142-000
899-681/450-000
899-681/450-000
899-682
899-682
Цветblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackblackwhitewhitewhitewhite
Contact materialCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treatedCopper or copper alloy, surface-treated
Country of originDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDEDE
Degree of protectionIP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20IP20
Габариты: глубина145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch145 mm / 5.709 inch
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN40551433156304055143287654405514329013540551432901424055143290166405514329018040551432907154055143295550405514329299340551432930374055143293006405514329302040551432930134055143294157405514329434840551432943934055143295086405514327096040551432695994055143295123405514329513040551432717214055143308366405514329620540551432962434055143302210405514330222740551433032794055143304573405514330512940551433051984055143305167405514330517440551433053414055143305389405514330540240551433057304055143305778405514330579240551433058154055143305846405514330587740551433058914055143305921405514330594540551433059524055143278393405514330609640551433156234055143306485405514330649240551433083594055143306522405514331566140551433065394055143308298405514330831140551433083284055143308335405514330834240551433084414055143315715
Height30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Locking of plug-in connectionlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking leverlocking lever
Mismating protectionYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Packaging typeBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOXBOX
Rated current, A252525252525252525252525252525252525252025520252525252525252525252525252525252020202025166201625201625252525252025
Rated current (2), A1616161616161616
Rated impulse voltage (III / 3), kV6464446446646444444644444446666664444444444664644446466666
Rated impulse voltage (III / 3) 2, kV4444444444444444444
Rated voltage (III / 3), В400250400250250250400250250400400250400250250250250250250400250250250250250250250400400400400400400250250250250250250250250250250400400250400250250250250400250400400400400400
Rated voltage (III / 3) 2, В250250250250250250250250250250250250250250250250250250250
Surrounding air (operating) temperature-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C-35 … 85 °C
Type of mounting, Secured to mounting plateWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapterWall screw adapter
Вес, г195.43466435440426376.651400440400450465393.701527389.832376.501359.286388335.691343.602420366.892442420370420440353.191466.509444440403394.5396.602394.442375334.071380435323.036450441.149400368.149415.895383.21360258.4390186.79438.01561.595409.594561.545196.34470440445440342281.021377.51192.55
Ширина190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch190 mm / 7.48 inch
На английском языке: Datasheet Wago 899
