Datasheet Texas Instruments DAC53608RTET — Даташит
СерияDAC53608
МодельDAC53608RTET
10-битный, 8-канальный, I2C, ЦАП с выходом напряжения в миниатюрном корпусе QFN 16-WQFN -40 to 125
DACx3608 Octal, 10-Bit or 8-Bit, I2CTM Interface, Buffered Voltage Output DACs in Tiny 3 × 3 WQFN Package datasheet
PDF, 2.9 Мб, Версия: A, Файл опубликован: 7 дек 2018
35 предложений от 14 поставщиков
IC DAC 10BIT V-OUT 16WQFN. 10 Bit Digital to Analog Converter 8 16-WQFN (3x3). Data Acquisition - Digital to Analog Converters...
DAC53608RTET
от 1 242 ₽
Эиком
DAC53608RTET
от 1 277 ₽
DAC53608RTET
1 543 ₽
Hi-Tech Circuit Group
DAC53608RTET
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаD53608
Width (мм)3
Length (мм)3
Thickness (мм)0.75
Pitch (мм)0.5
Max Height (мм)0.8
Approx. price1.39 | 1ku US$
АрхитектураString
DAC channels8
Основные особенностиCost Optimized,Low Power,Small Size
INL(Max)1 +/-LSB
InterfaceI2C
Operating temperature range-40 to 125 C
Output range(Max)5.5 mA/V
Output typeBuffered Voltage
Package GroupWQFN|16
Package size: mm2:W x L16WQFN: 9 mm2: 3 x 3 (WQFN|16) PKG
Power consumption(Typ)0.1 mW
Reference: typeExt
Разрешение10 Bits
Settling time10 µs
  • Evaluation Modules & Boards: DAC53608EVM
    DAC53608 10-bit; I2C interface; buffered-voltage-output DAC evaluation module
  • Octal Programmable Comparator Using DAC53608
    PDF, 95 Кб, Файл опубликован: 26 июл 2018
    Protection circuits are a necessary overhead in products designed for robustness. Achieving such protection with least amount of trade-off is always the goal of a product developer. The DACx3608 family of DACs offer a solution to one suchchallenge of circuit protection by enabling efficient power supply voltage and current supervision.
  • DAC53608 Delivers Ultra Low Cost LED Array Biasing Solution
    PDF, 44 Кб, Файл опубликован: 26 июл 2018
    Packed with a simple yet complete feature set the DAC53608 enables a biasing solution for LED arrays that is low-cost compact and adequate. Though it may be unobvious meeting all these requirements needs careful design trade-offs.
  • Power-supply margining circuit for LDOs using a precision DAC
    PDF, 175 Кб, Файл опубликован: 25 янв 2019
  • Power-supply margining circuit for SMPS using a precision DAC
    PDF, 204 Кб, Файл опубликован: 25 янв 2019
Серия: DAC53608 (2)
  • Semiconductors > Analog and Mixed-Signal > Data converters > Digital-to-analog converters (DACs) > Precision DACs (<=10MSPS)
На английском языке: Datasheet Texas Instruments DAC53608RTET
