Datasheet IDT XPC736156.250000I — Даташит
| Производитель | IDT |
| Серия | XP |
| Модель | XPC736156.250000I |
150fs кварцевый PLL-генератор
150fs Quartz-based PLL Oscillator
800.000000 MHz Crystal
Oscillator XPL536800.000000I
Datasheet Addendum General Configuration
Parameter Value Jitter < 150 fs Package 5 x 3.2 mm Output Frequency 800.000000 MHz Frequency Stability ± 25 ppm VDD Voltage 3.3 V Output Type LVDS Output Enable/Disable Position (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignment
Pin Number Pin Name Description 1 OE Output Enable (0 = output disabled; pulled high internally) 2 NC No connect 3 GND 4 Output 0 Output 5 Output 0b Complementary output 6 VDD 7 SDA (NA) Serial data (Not active for XO mode) 8 SCL (NA) Serial Clock (Not active for XO mode) Connect to ground Supply voltage Corporate Headquarters
6024 Silver Creek Valley Road
San Jose, CA 95138 USA
www.IDT.com Sales
1-800-345-7015 or 408-284-8200
Fax: 408-284-2775
www.IDT.com/go/sales Tech Support
www.IDT.com/go/support DISCLAIMER Integrated Device Technology, Inc. (IDT) and its affiliated companies (herein referred to as "IDT") reserve the right to modify the products and/or
specifications described herein at any time, without notice, at IDT's sole discretion. Performance specifications and operating parameters of the described products
are d etermined in an independent state and are not guaranteed to perform the same way when installed in customer products. The information contained herein is
provided without representation or warranty of a ny kind, whether express or implied, including, but not limited to, the suitability of IDT's products for any particular
purpose, an implied warranty of merchantability, or non-infringement of the intellectual property rights of others. This document is presented only as a guide and does
not convey any license under intellectual property rights of IDT or any third parties.
IDT's products are not intended for use in applications involving extreme environmental conditions or in life support systems or similar devices where the failure or
malfunction of an IDT product can be reasonably expected to significantly affect the health or safety of users. Anyone using an IDT product in such a manner does so
at their own risk, absent an express, written agreement by IDT.
Integrated Device Technology, IDT and the IDT logo are trademarks or registered trademarks of IDT and its subsidiaries in the United States and other countries.
Other trademarks used herein are the property of IDT or their respective third party owners. For datasheet type definitions and a glossary of common terms, visit
www.idt.com/go/glossary. All contents of this document are copyright of Integrated Device Technology, Inc. All rights reserved. ©2019 I …
156.250000 MHz Crystal
Oscillator XPP536156.250000I
Parameter Value Jitter < 150 fs Package 5 x 3.2 mm Output Frequency 156.250000 MHz Frequency Stability ± 25 ppm VDD Voltage 3.3 V Output Type LVPECL Output Enable/Disable Position (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignment
www.IDT.com Sales
Fax: 408-284-2775
www.idt.com/go/glossary. All contents of this document are copyright of Integrated Device Technology, Inc. All rights reserved. ©2019 …
312.500000 MHz Crystal
Oscillator XPP536312.500000I
Parameter Value Jitter < 150 fs Package 5 x 3.2 mm Output Frequency 312.500000 MHz Frequency Stability ± 25 ppm VDD Voltage 3.3 V Output Type LVPECL Output Enable/Disable Position (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignment
www.IDT.com Sales
Fax: 408-284-2775
625.000000 MHz Crystal
Oscillator XPP536625.000000I
Parameter Value Jitter < 150 fs Package 5 x 3.2 mm Output Frequency 625.000000 MHz Frequency Stability ± 25 ppm VDD Voltage 3.3 V Output Type LVPECL Output Enable/Disable Position (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignment
www.IDT.com Sales
Fax: 408-284-2775
XP Family of Ultra-low Phase Noise
Quartz-based PLL Oscillators Description Features The XP devices are ultra-low phase noise quartz-based PLL
oscillators supporting a large range of frequencies and output
interface types. These devices are designed to operate at three
different power supplies and are available in three package sizes
with several pinout configurations, as well as three operational
temperature ranges. ▪ Output types: LVDS, LVPECL, CML XP Datasheet • Frequency range: 15MHz to 2100MHz
▪ Output type: HCSL • Frequency range: 15MHz to 725MHz
▪ Supply voltage options: 1.8V, 2.5V, or 3.3V
▪ Phase jitter (12kHz to 20MHz): 120fs typical
▪ Package options: The XP devices can be programmed to generate an output
frequency from 15MHz to 2100MHz with a resolution as low as
1Hz accuracy. The configuration capability of this family of devices
allows for fast delivery times for both sample and large production
orders. • 7.0 × 5.0 × 1.7 mm
• 5.0 × 3.2 × 1.17 mm
• 3.2 × 2.5 × 1.07 mm Parts are for one time programming (OTP) at the factory for a
fixed frequency application, or can be field programmable using
I2C, based on system needs (see note 1 under Pin Descriptions). ▪ Operating temperatures and frequency stability: • -40°C to +85°C, ±25ppm
• -40°C to +105°C, ±50ppm Pin Assignments
Figure 1. 7.0 × 5.0 mm, 5.0 × 3.2 mm, and 3.2 × 2.5 mm Packages SDA
7
OE 1 6 VDD NC 2 5 OUT0b GND 3 4 OUT0 …
156.250000MHz Crystal
Oscillator XPP736156.250000I Datasheet Addendum General Configuration
Parameter Value Device Version XP version (150fs phase jitter) Package 7.0mm × 5.0mm Output Frequency 156.250000MHz Frequency Stability ±25ppm VDD Voltage 3.3V Output Type LVPECL Output Enable/Disable (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignments
Number Name Description 1 OE Output Enable. 2 NC No connect. 3 GND Connect to ground. 4 OUT0 Output. 5 OUT0b Complementary output. 6 VDD Supply voltage. 7 SDA Serial data. Not used for XO mode. 8 SCL Serial clock. Not used for XO mode. ©2019 Integrated Device Technology, Inc. 1 February 21, 2019 XPP736156.250000I Datasheet Addendum Revision History
Revision Date
February 21, 2019 Description of Change
Initial release. Corporate Headquarters Sales Tech Support 6024 Silver Creek Valley Road
www.IDT.com 1-800-345-7015 or 408-284-8200
Fax: 408-284-2775
www.IDT.com/go/sales www.IDT.com/go/support DISCLAIMER Integrated Device Technology, Inc. (IDT) and its affiliated companies (herein referred to as "IDT") reserve the right to modify the products and/or specifications described herein at any time,
without notice, at IDT's sole discretion. Performance specifications and operating parameters of the described products are determined in an independent state and are not guaranteed to perform the same
way when installed in customer products. The information contained herein is provided without representation or warranty of any kind, whether express or implied, including, but not limited to, the suitability
of IDT's products for any particular purpose, an implied warranty of merchantability, or non-infringement of the intellectual property rights of others. This document is presented only as a guide and does not
IDT's products are not intended for use in applications involving extreme environmental conditions or in life support systems or similar devices where the failure or malfunction of an IDT product can be reasonably expected to significantly affect the health or safety of users. Anyone using an IDT product in such a manner does so at their own risk, absent an express, written agreement by IDT.
Integrated Device Technology, IDT and the IDT logo are trademarks or registered trademarks of IDT and its subsidiaries in the United States and other countries. Other trademarks used herein are the property
of IDT or their respective third party owners. For datasheet type definitions and a glossary of common ter …
312.500000MHz Crystal
Oscillator XPP736312.500000I Datasheet Addendum General Configuration
Parameter Value Device Version XP version (150fs phase jitter) Package 7.0mm × 5.0mm Output Frequency 312.500000MHz Frequency Stability ±25ppm VDD Voltage 3.3V Output Type LVPECL Output Enable/Disable (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignments
Number Name Description 1 OE Output Enable. 2 NC No connect. 3 GND Connect to ground. 4 OUT0 Output. 5 OUT0b Complementary output. 6 VDD Supply voltage. 7 SDA Serial data. Not used for XO mode. 8 SCL Serial clock. Not used for XO mode. ©2019 Integrated Device Technology, Inc. 1 February 21, 2019 XPP736312.500000I Datasheet Addendum Revision History
Revision Date
Fax: 408-284-2775
Oscillator XPC736156.250000I Datasheet Addendum General Configuration
Parameter Value Device Version XP version (150fs phase jitter) Package 7.0mm × 5.0mm Output Frequency 156.250000MHz Frequency Stability ±25ppm VDD Voltage 3.3V Output Type CML Output Enable/Disable (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignments
Number Name Description 1 OE Output Enable. 2 NC No connect. 3 GND Connect to ground. 4 OUT0 Output. 5 OUT0b Complementary output. 6 VDD Supply voltage. 7 SDA Serial data. Not used for XO mode. 8 SCL Serial clock. Not used for XO mode. ©2019 Integrated Device Technology, Inc. 1 February 21, 2019 XPC736156.250000I Datasheet Addendum Revision History
Revision Date
Fax: 408-284-2775
of IDT or their respective third party owners. For datasheet type definitions and a glossary of common terms, …
625.000000MHz Crystal
Oscillator XPP736625.000000I Datasheet Addendum General Configuration
Parameter Value Device Version XP version (150fs phase jitter) Package 7.0mm × 5.0mm Output Frequency 625.000000MHz Frequency Stability ±25ppm VDD Voltage 3.3V Output Type LVPECL Output Enable/Disable (E/D) Position Pin 1 Temperature Grade -40°C to +85°C Pin Assignments
Number Name Description 1 OE Output Enable. 2 NC No connect. 3 GND Connect to ground. 4 OUT0 Output. 5 OUT0b Complementary output. 6 VDD Supply voltage. 7 SDA Serial data. Not used for XO mode. 8 SCL Serial clock. Not used for XO mode. ©2019 Integrated Device Technology, Inc. 1 February 21, 2019 XPP736625.000000I Datasheet Addendum Revision History
Revision Date
Fax: 408-284-2775
Купить XPC736156.250000I на РадиоЛоцман.Цены — от 253 до 2 110 ₽22 предложений от 10 поставщиков Oscillator, 156.25MHz, 25ppm, SMD, 7mm x 5mm, 3.3V Supply, CML Out, XP Series | |||
| XPC736156.250000I Renesas | 253 ₽ | ||
| XPC736156.250000I Renesas | от 1 367 ₽ | ||
| XPC736156.250000I | от 1 370 ₽ | ||
| XPC736156.250000I Renesas | от 2 110 ₽ | ||
| Код корпуса производителя | JD8 |
- Clocks & Timing > Crystal Oscillators > 150fs Quartz-based PLL Oscillator
