PDF, 633 Кб, Язык: анг., Файл закачен: 16 авг 2017, Страниц: 32
Single Chip 12-Bit Data Acquisition System
LTC1290
Acquisition System U FEATURES DESCRIPTIO ■ The LTC®1290 is a data acquisition component which
contains a serial I/O successive approximation A/D converter. It uses LTCMOSTM switched capacitor technology
to perform either 12-bit unipolar or 11-bit plus sign bipolar
A/D conversions. The 8-channel input multiplexer can be
configured for either single-ended or differential inputs (or
combinations thereof). An on-chip sample-and-hold is
included for all single-ended input channels. When the
LTC1290 is idle it can be powered down with a serial word
in applications where low power consumption is desired. ■
■ Software Programmable Features
– Unipolar/Bipolar Conversion
– Four Differential/Eight Single-Ended Inputs
– MSB-or LSB-First Data Sequence
– Variable Data Word Length
– Power Shutdown
Built-In Sample-and-Hold
Single Supply 5V or ±5V Operation
Direct Four-Wire Interface to Most MPU Serial Ports …
