Datasheet Texas Instruments TPS63802DLAR — Даташит
СерияTPS63802
МодельTPS63802DLAR
Высокоточный, высокоэффективный одноиндукторный понижающе-повышающий преобразователь 10-VSON-HR -40 to 125
TPS63802 2-A, high-efficient, low IQ buck-boost converter with small solution size datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 30 янв 2019
Pin10
Package TypeDLA
Package QTY3000
Маркировка63802
Width (мм)2
Length (мм)3
Thickness (мм)0.9
Approx. price0.98 | 1ku US$
Duty cycle(Max)100 %
Основные особенностиEnable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed
Iout(Max)2 A
Iq(Typ)0.011 мА
Operating temperature range-40 to 125 C
Package GroupVSON-HR|10
Switch current limit(Min)3.9 A
Switch current limit(Typ)4.5 A
Switching frequency(Max)2500 kHz
Switching frequency(Min)2500 kHz
TopologyBuck-Boost,Buck/Boost
ТипConverter
Vin(Max)5.5 В
Vin(Min)1.3 В
Vout(Max)5 В
Vout(Min)1.8 В
  • Evaluation Modules & Boards: TPS63802EVM
    TPS63802 high current; high efficiency buck boost converter evaluation module
  • Selecting a DC/DC Converter for Maximum Battery Life in Pulsed-Load Applications
    PDF, 155 Кб, Файл опубликован: 28 ноя 2018
    When designing a battery powered system maximizing batterylife is one of the most important design goals. Battery powered systems such as smart meters IoT sensors or ireless medical equipment often require a power converter to obtain fixed supply voltages for time varying loads
  • Prevent Battery Overdischarge with Precise Threshold Enable Pin
    PDF, 78 Кб, Файл опубликован: 2 апр 2019
    Using a buck-boost converter is a convenient way to obtain a fixed supply voltage within the wide voltage range of typical batteries used in low-power devices such as smart meters wearables or those in the Internet of Things.
  • Selecting the right DC/DC converter for maximum battery life
    PDF, 72 Кб, Файл опубликован: 8 фев 2019
    Choosing the best topology for a battery powered application such as IoT sensor smart lock or IP camera might not always be straightforward based on the available and required voltages alone.
  • Using Non-Inverting Buck-Boost Converter for Voltage Stabilization
    PDF, 734 Кб, Файл опубликован: 1 авг 2019
  • Supercapacitor backup power supply with TPS63802
    PDF, 665 Кб, Файл опубликован: 21 янв 2019
  • Precise Delayed Start-up with Precise Threshold Enable-pin
    PDF, 188 Кб, Файл опубликован: 15 апр 2019
  • Buck-boost Converter Battery Life Time Estimation for Wireless Network Cameras (Rev. A)
    PDF, 123 Кб, Версия: A, Файл опубликован: 28 май 2019
  • Buck-Boost Converters Solving Power Challenges in Optical Modules
    PDF, 45 Кб, Файл опубликован: 13 май 2019
  • Improving Load Transient Response for Controlled Loads
    PDF, 338 Кб, Файл опубликован: 12 сен 2019
  • Basic Calculations of a 4 Switch Buck-Boost Power Stage (Rev. B)
    PDF, 400 Кб, Версия: B, Файл опубликован: 9 июл 2018
    This application note gives the equations to calculate the power stage of a non-inverting buck-boost converter built with an IC with integrated switches and operating in continuous conduction mode. See the references at the end of this document if more detail is needed.
Серия: TPS63802 (3)
  • Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Buck-boost & inverting > Buck-boost, inverting & split-rail converters (integrated switch)
На английском языке: Datasheet Texas Instruments TPS63802DLAR
