Datasheet Texas Instruments TPS63805 — Даташит
СерияTPS63805
2-А, высокоэффективный, низкотоковой понижающе-повышающий преобразователь с миниатюрным размером решения
TPS6380x 2-A, High-efficient, Low IQ Buck-boost Converter with Small Solution Size datasheet
PDF, 3.2 Мб, Версия: B, Файл опубликован: 20 ноя 2018
TPS63805YFFRTPS63805YFFT
N12
Pin1515
Package TypeYFFYFF
Industry STD TermDSBGADSBGA
JEDEC CodeR-XBGA-NR-XBGA-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаTPS63805TPS63805
Thickness (мм)0.40.4
Pitch (мм)0.40.4
Max Height (мм)0.6250.625
Parameters / ModelsTPS63805YFFRTPS63805YFFT
Approx. price, US$0.98 | 1ku0.98 | 1ku
Duty cycle(Max), %100100
Основные особенностиEnable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO FixedEnable,Light Load Efficiency,Load Disconnect,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed
Iout(Max), A22
Iq(Typ), мА0.0110.011
Operating temperature range, C-40 to 125-40 to 125
Package GroupDSBGA|15DSBGA|15
RatingCatalogCatalog
Switch current limit(Min), A3.93.9
Switch current limit(Typ), A55
Switching frequency(Max), kHz31003100
Switching frequency(Min), kHz500500
TopologyBuck-Boost,Buck/BoostBuck-Boost,Buck/Boost
ТипConverterConverter
Vin(Max), В5.55.5
Vin(Min), В1.31.3
Vout(Max), В5.25.2
Vout(Min), В1.81.8
RoHSСовместимСовместим
  • Prevent Battery Overdischarge with Precise Threshold Enable Pin
    PDF, 78 Кб, Файл опубликован: 2 апр 2019
    Using a buck-boost converter is a convenient way to obtain a fixed supply voltage within the wide voltage range of typical batteries used in low-power devices such as smart meters wearables or those in the Internet of Things.
  • Selecting the right DC/DC converter for maximum battery life
    PDF, 72 Кб, Файл опубликован: 8 фев 2019
    Choosing the best topology for a battery powered application such as IoT sensor smart lock or IP camera might not always be straightforward based on the available and required voltages alone.
  • Selecting a DC/DC Converter for Maximum Battery Life in Pulsed-Load Applications
    PDF, 155 Кб, Файл опубликован: 28 ноя 2018
    When designing a battery powered system maximizing batterylife is one of the most important design goals. Battery powered systems such as smart meters IoT sensors or ireless medical equipment often require a power converter to obtain fixed supply voltages for time varying loads
  • Using Non-Inverting Buck-Boost Converter for Voltage Stabilization
    PDF, 734 Кб, Файл опубликован: 1 авг 2019
  • Supercapacitor backup power supply with TPS63802
    PDF, 665 Кб, Файл опубликован: 21 янв 2019
  • Precise Delayed Start-up with Precise Threshold Enable-pin
    PDF, 188 Кб, Файл опубликован: 15 апр 2019
  • Low-power TEC driver
    PDF, 75 Кб, Файл опубликован: 18 ноя 2014
    TPS63020 Low Power TEC Driver
  • Different methods to drive LEDs using TPS63xxx buck-boost converters (Rev. B)
    PDF, 86 Кб, Версия: B, Файл опубликован: 12 янв 2012
  • Buck-boost Converter Battery Life Time Estimation for Wireless Network Cameras (Rev. A)
    PDF, 123 Кб, Версия: A, Файл опубликован: 28 май 2019
  • Buck-Boost Converters Solving Power Challenges in Optical Modules
    PDF, 45 Кб, Файл опубликован: 13 май 2019
  • Improving Load Transient Response for Controlled Loads
    PDF, 338 Кб, Файл опубликован: 12 сен 2019
  • Extending the Soft Start Time in the TPS63010 Buck-Boost Converter
    PDF, 262 Кб, Файл опубликован: 5 дек 2012
  • Basic Calculations of a 4 Switch Buck-Boost Power Stage (Rev. B)
    PDF, 400 Кб, Версия: B, Файл опубликован: 9 июл 2018
    This application note gives the equations to calculate the power stage of a non-inverting buck-boost converter built with an IC with integrated switches and operating in continuous conduction mode. See the references at the end of this document if more detail is needed.
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
Серия: TPS63805 (2)
  • Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Buck-boost & inverting > Buck-boost, inverting & split-rail converters (integrated switch)
На английском языке: Datasheet Texas Instruments TPS63805
