Datasheet Texas Instruments XPS63810YFFT — Даташит
СерияTPS63810
МодельXPS63810YFFT
2,5-А высокоэффективный повышающе-понижающий преобразователь с интерфейсом I²C 15-DSBGA -40 до 85
TPS63810 2.5-A Buck-Boost Converter with I2C Interface datasheet
PDF, 1.3 Мб, Файл опубликован: 12 янв 2018
Pin15
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
Thickness (мм)0.4
Pitch (мм)0.4
Max Height (мм)0.625
Approx. price1.09 | 1ku US$
Duty cycle(Max)100 %
Основные особенностиDynamic Voltage Scaling,Enable,Light Load Efficiency,Load Disconnect,Output Discharge,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Fixed
Iout(Max)2.5 A
Iq(Typ)0.013 мА
Operating temperature range-40 to 85 C
Package GroupDSBGA|15
Switch current limit(Min)5.2 A
Switch current limit(Typ)5.8 A
Switching frequency(Max)3100 kHz
Switching frequency(Min)500 kHz
TopologyBuck-Boost,Buck/Boost
ТипConverter
Vin(Max)5.5 В
Vin(Min)1.9 В
Vout(Max)5.2 В
Vout(Min)1.825 В
RoHSSee ti.com
  • Improve Efficiency in TWS Earbuds with Buck-Boost Converter
    PDF, 86 Кб, Файл опубликован: 18 сен 2019
  • Selecting a DC/DC Converter for Maximum Battery Life in Pulsed-Load Applications
    PDF, 155 Кб, Файл опубликован: 28 ноя 2018
    When designing a battery powered system maximizing batterylife is one of the most important design goals. Battery powered systems such as smart meters IoT sensors or ireless medical equipment often require a power converter to obtain fixed supply voltages for time varying loads
  • Prevent Battery Overdischarge with Precise Threshold Enable Pin
    PDF, 78 Кб, Файл опубликован: 2 апр 2019
    Using a buck-boost converter is a convenient way to obtain a fixed supply voltage within the wide voltage range of typical batteries used in low-power devices such as smart meters wearables or those in the Internet of Things.
  • Selecting the right DC/DC converter for maximum battery life
    PDF, 72 Кб, Файл опубликован: 8 фев 2019
    Choosing the best topology for a battery powered application such as IoT sensor smart lock or IP camera might not always be straightforward based on the available and required voltages alone.
  • Supercapacitor backup power supply with TPS63802
    PDF, 665 Кб, Файл опубликован: 21 янв 2019
  • Using Non-Inverting Buck-Boost Converter for Voltage Stabilization
    PDF, 734 Кб, Файл опубликован: 1 авг 2019
  • Precise Delayed Start-up with Precise Threshold Enable-pin
    PDF, 188 Кб, Файл опубликован: 15 апр 2019
  • Buck-boost Converter Battery Life Time Estimation for Wireless Network Cameras (Rev. A)
    PDF, 123 Кб, Версия: A, Файл опубликован: 28 май 2019
  • Buck-Boost Converters Solving Power Challenges in Optical Modules
    PDF, 45 Кб, Файл опубликован: 13 май 2019
  • Basic Calculations of a 4 Switch Buck-Boost Power Stage (Rev. B)
    PDF, 400 Кб, Версия: B, Файл опубликован: 9 июл 2018
    This application note gives the equations to calculate the power stage of a non-inverting buck-boost converter built with an IC with integrated switches and operating in continuous conduction mode. See the references at the end of this document if more detail is needed.
Серия: TPS63810 (2)
  • Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Buck-boost & inverting > Buck-boost, inverting & split-rail converters (integrated switch)
На английском языке: Datasheet Texas Instruments XPS63810YFFT
