Datasheet Diodes B340 — Даташит
| Производитель | Diodes |
| Серия | B340 |
Шоттки
Datasheet B320, B330, B340, B350, B360
PDF, 344 Кб, Язык: анг., Файл закачен: 27 мар 2020, Страниц: 5
3.0A Surface Mount Schottky Barrier Rectifier
Купить B340-13-F на РадиоЛоцман.Цены — от 2.70 до 56 ₽47 предложений от 19 поставщиков Дискретные полупроводники Диоды — выпрямители — одиночные | |||
| B340-13-F Multicomp | 23 ₽ | ||
| B340-13-F | по запросу | ||
| B340-13-F Diodes | по запросу | ||
| B340-13-F | B340A-13-F | B340AE-13 | B340AF-13 | B340AQ-13-F | B340B-13-F | B340BE-13 | B340BQ-13-F | B340CE-13 | B340LA-13-F | B340LB-13-F | B340Q-13-F | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Корпус | SMC | SMC | SMC | SMC | SMC | SMC | SMC | SMC | SMC | SMC | SMC | SMC |
| Parameters / Models | B340-13-F | B340A-13-F | B340AE-13 | B340AF-13 | B340AQ-13-F | B340B-13-F | B340BE-13 | B340BQ-13-F | B340CE-13 | B340LA-13-F | B340LB-13-F | B340Q-13-F |
| @ IF | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A |
| @ Terminal Temperature TT | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC | 100 ºC |
| @ VR | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V |
| Automotive Compliant PPAP | No | No | No | No | No | No | No | No | No | No | No | No |
| Configuration | Single | Single | Single | Single | Single | Single | Single | Single | Single | Single | Single | Single |
| Forward Voltage Drop VF (V) | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| Maximum Average Rectified Current IO | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A | 3 A |
| Maximum Reverse Current IR | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA | 500 µA |
| Peak Forward Surge Current IFSM | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A | 100 A |
| Peak Repetitive Reverse Voltage VRRM | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V | 40 V |
| Qualified to AECQ10x | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Total Capacitance CT | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF | 200 pF |
Серия: B340 (12)
- Discrete > Diodes and Rectifiers > Rectifiers > Schottky (.5A and Above)
