Datasheet Texas Instruments XPS63900DSKT — Даташит
| Серия | TPS63900 |
| Модель | XPS63900DSKT |
Понижающе-повышающий преобразователь Iq 400 мА, 200 нА, 1,8 В-5,5 ВIN, ограничение входного тока, динамическое масштабирование напряжения 10-SON от -40 до 85
TPS63900 1.8-V to 5.5-V, 400-mA, 200-nA Quiescent Current Buck-Boost Converter datasheet
PDF, 1.8 Мб, Версия: A, Файл опубликован: 24 апр 2020
| Pin | 10 |
| Package Type | DSK |
| Industry STD Term | WSON |
| JEDEC Code | S-PDSO-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Width (мм) | 2.5 |
| Length (мм) | 2.5 |
| Thickness (мм) | 0.75 |
| Pitch (мм) | 0.5 |
| Max Height (мм) | 0.8 |
| Mechanical Data | Скачать |
| Approx. price | 0.92 | 1ku US$ |
| Duty cycle(Max) | 99 % |
| Основные особенности | Adjustable Current Limit,Dynamic Voltage Scaling,Enable,Light Load Efficiency,Pre-Bias Start-Up,UVLO Fixed |
| Iout(Max) | 0.4 A |
| Iq(Typ) | 0.0002 мА |
| Operating temperature range | -40 to 85 C |
| Package Group | SON|10 |
| Rating | Catalog |
| Switch current limit(Min) | 1.33 A |
| Switch current limit(Typ) | 1.9 A |
| Switching frequency(Max) | 2200 kHz |
| Switching frequency(Min) | 0.01 kHz |
| Topology | Buck-Boost |
| Vin(Max) | 5.5 В |
| Vin(Min) | 1.8 В |
| Vout(Max) | 5 В |
| Vout(Min) | 1.8 В |
| RoHS | See ti.com |
- Evaluation boards: TPS63900EVM
TPS63900 low Iq buck-boost converter evaluation module
- Extending Battery Life with Low-Iq and Dynamic Voltage ScalingPDF, 342 Кб, Файл опубликован: 1 апр 2020
When designing a battery powered system maximizing battery life is often one of the most important design goals. This is especially true in applications such as smart and IoT sensors or wireless medical equipment where some parts need to operate continuously at a low power level and the cost of replacing the battery is high. Selecting the right converter to obtain a fixed system voltage in such a - Using Input Current Limiting to Extend Battery LifePDF, 240 Кб, Файл опубликован: 28 апр 2020
- Layer Design for Reducing Radiated EMI of DC to DC Buck-Boost ConvertersPDF, 950 Кб, Файл опубликован: 22 апр 2020
Серия: TPS63900 (3)
- TPS63900DSKR TPS63900DSKT XPS63900DSKT
- Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Buck-boost & inverting regulators > Buck-boost, inverting & split-rail converters (integrated switch)
