Datasheet Texas Instruments TPS628512 — Даташит
| Серия | TPS628512 |
Понижающий преобразователь 2,7 В в 6 В, 2 А, с фиксированной частотой, в корпусе SOT583
Datasheet
Купить TPS628512 на РадиоЛоцман.Цены — от 16 до 4 756 ₽32 предложений от 11 поставщиков , 2.7-V to 6-V, 2-A, fixed-frequency, step-down converter in SOT583 package 8-SOT-5X3 -40 to 150 | |||
| TPS628512DRLR Texas Instruments | 35 ₽ | ||
| TPS628512EVM-139 Texas Instruments | 4 756 ₽ | ||
| TPS628512EVM-139 Texas Instruments | по запросу | ||
| TPS628512DRLR Texas Instruments | по запросу | ||
| TPS628512DRLR | XPS628512DRLR | |
| Статус продукта | Анонсирован | Анонсирован |
| Доступность образцов у производителя | Нет | Нет |
| N | 1 | 2 |
| Pin | 8 | 8 |
| Package Type | DRL | DRL |
| Industry STD Term | SOT-5X3 | SOT-5X3 |
| JEDEC Code | R-PCSO-N | R-PCSO-N |
| Package QTY | 4000 | 4000 |
| Carrier | LARGE T&R | LARGE T&R |
| Width (мм) | 1.2 | 1.2 |
| Length (мм) | 2.1 | 2.1 |
| Thickness (мм) | 0.55 | 0.55 |
| Pitch (мм) | 0.5 | 0.5 |
| Max Height (мм) | 0.6 | 0.6 |
| Parameters / Models | TPS628512DRLR | XPS628512DRLR |
| Control mode | Current Mode | Current Mode |
| Duty cycle(Max), % | 100 | 100 |
| Основные особенности | Enable,Forced PWM,Frequency Synchronization,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Soft Start Adjustable,Synchronous Rectification,Tracking,UVLO Adjustable | Enable,Forced PWM,Frequency Synchronization,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Soft Start Adjustable,Synchronous Rectification,Tracking,UVLO Adjustable |
| Iout, A | 2 | 2 |
| Iout(Max), A | 2 | 2 |
| Iq(Typ), uA | 0.015 | 0.015 |
| Operating temperature range, C | -40 to 150 | -40 to 150 |
| Package Group | SOT-5X3|8 | SOT-5X3|8 |
| Package size: mm2:W x L, PKG | 8SOT-5X3: 3 mm2: 1.2 x 2.1 (SOT-5X3|8) | 8SOT-5X3: 3 mm2: 1.2 x 2.1 (SOT-5X3|8) |
| Rating | Catalog | Catalog |
| Regulated outputs | 1 | 1 |
| Switching frequency(Max), kHz | 2475 | 2475 |
| Switching frequency(Min), kHz | 2025 | 2025 |
| Switching frequency(Typ), kHz | 2250 | 2250 |
| Тип | Converter | Converter |
| Vin(Max), В | 6 | 6 |
| Vin(Min), В | 2.7 | 2.7 |
| Vout(Max), В | 5.5 | 5.5 |
| Vout(Min), В | 0.6 | 0.6 |
| RoHS | See ti.com | See ti.com |
Серия: TPS628512 (2)
- Semiconductors > Analog and Mixed-Signal > Power management > DC/DC switching regulators > Step-down (buck) regulators > Buck converters (integrated switch)
