Datasheet Microchip PIC18F26Q43-E/STX — Даташит
| Производитель | Microchip |
| Серия | PIC18F26Q43 |
| Модель | PIC18F26Q43-E/STX |
Универсальные микроконтроллеры с возможностью настройки оборудования
Datasheet PIC18F26/46/56Q43
PDF, 12.2 Мб, Язык: анг., Файл закачен: 28 дек 2020
28/40/44/48-Pin, Low-Power, High-PerformanceMicrocontroller with XLP Technology
 Купить PIC18F26Q43-E/STX на РадиоЛоцман.Цены — от 44 до 274 ₽22 предложений от 9 поставщиков 8-bit Microcontrollers - MCU 64KB Flash, 4KB RAM, 1KB EEPROM, 12b ADC2, 5b DAC, Comp, PWM, CCP, CWG, HLT, WWDT, SCAN/CRC,...  | |||
| PIC18F26Q43-E/STX | от 106 ₽ | ||
| PIC18F26Q43-E/STX Microchip  | от 226 ₽ | ||
| PIC18F26Q43-E/STX Microchip  | от 248 ₽ | ||
| PIC18F26Q43-E/STX Microchip  | от 251 ₽ | ||
| Корпус | VQFN |
| ADC Input | 24 |
| ADC with Computation | Yes |
| Angular Timer | No |
| CRC | Yes |
| Class B Support | No |
| Complementary Waveform Generator / Complementary Output Generator | 3 |
| Configurable Logic Cell | 8 CLC/CCL |
| Data Signal Modulator | 1 |
| Emulated EEPROM in Flash | 1024 |
| Hardware Limit Timer | 3 |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 64MHZ |
| Internal Voltage Reference | Yes Bandgap |
| Lead Count | 28 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 4 |
| Max 8-Bit Digital Timers | 3 |
| Max ADC Resolution | 12 Bits |
| Max CPU Speed | 64 МГц |
| Max DAC Resolution | 8 Bits |
| Max PWM outputs | 6 including complementary |
| Количество компараторов | 2 |
| Number of DACs | 1 |
| Numerically Controlled Oscillator | 3 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 16 Bits |
| Peripheral Pin Select / Pin Muxing | Yes |
| Pin count | 28 |
| Размер памяти программ | 64 KB |
| SPI | 2 |
| SRAM | 4096 Bytes |
| Signal Measurement Timer | 1 |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 5 |
| Zero Cross detect | Yes |
Серия: PIC18F26Q43 (15)
PIC18F26Q43E/STX, PIC18F26Q43 E/STX
