Datasheet Microchip PIC18F26Q43-E/SP — Даташит
Производитель | Microchip |
Серия | PIC18F26Q43 |
Модель | PIC18F26Q43-E/SP |
Универсальные микроконтроллеры с возможностью настройки оборудования
Datasheet PIC18F26/46/56Q43
PDF, 12.2 Мб, Язык: анг., Файл закачен: 28 дек 2020
28/40/44/48-Pin, Low-Power, High-PerformanceMicrocontroller with XLP Technology
![]() 15 предложений от 8 поставщиков 8-bit Microcontrollers - MCU 64KB Flash, 4KB RAM, 1KB EEPROM, 12b ADC2, 5b DAC, Comp, PWM, CCP, CWG, HLT, WWDT, SCAN/CRC,... | |||
PIC18F26Q43-E/SP | от 151 ₽ | ||
PIC18F26Q43-E/SP Microchip | 188 ₽ | ||
PIC18F26Q43-E/SP Microchip | от 326 ₽ | ||
PIC18F26Q43-E/SP Microchip | 385 ₽ |
Корпус | SPDIP |
ADC Input | 24 |
ADC with Computation | Yes |
Angular Timer | No |
CRC | Yes |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 3 |
Configurable Logic Cell | 8 CLC/CCL |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 1024 |
Hardware Limit Timer | 3 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 64MHZ |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 3 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 64 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 6 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 3 |
PWM Max Resolution | 16 Bits |
Pin count | 28 |
Размер памяти программ | 64 KB |
SPI | 2 |
SRAM | 4096 Bytes |
Signal Measurement Timer | 1 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 5 |
Zero Cross detect | Yes |
Серия: PIC18F26Q43 (15)
PIC18F26Q43E/SP, PIC18F26Q43 E/SP
