Datasheet Microchip PIC18F27Q43T-I/ML — Даташит
| Производитель | Microchip |
| Серия | PIC18F27Q43 |
| Модель | PIC18F27Q43T-I/ML |
Универсальные микроконтроллеры с возможностью настройки оборудования
Datasheet PIC18F27/47/57Q43
PDF, 12.2 Мб, Язык: анг., Файл закачен: 28 дек 2020
28/40/44/48-Pin, Low-Power, High-PerformanceMicrocontroller with XLP Technology
|  Купить PIC18F27Q43T-I на РадиоЛоцман.Цены — от 109 до 352 ₽ 24 предложений от 11 поставщиков IC: микроконтроллер PIC; SRAM: 8kБ; EEPROM: 1kБ; 64МГц; 1,8÷5,5ВDC | |||
| PIC18F27Q43T-I/STX | 133 ₽ | ||
| PIC18F27Q43T-I/STX Microchip | от 228 ₽ | ||
| PIC18F27Q43T-I/STX Microchip | от 252 ₽ | ||
| PIC18F27Q43T-I/SS Microchip | 352 ₽ | ||
| Корпус | QFN |
| ADC Input | 24 |
| ADC with Computation | Yes |
| Angular Timer | No |
| CRC | Yes |
| Class B Support | No |
| Complementary Waveform Generator / Complementary Output Generator | 3 |
| Configurable Logic Cell | 8 CLC/CCL |
| Data Signal Modulator | 1 |
| Emulated EEPROM in Flash | 1024 |
| Hardware Limit Timer | 3 |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 64MHZ |
| Internal Voltage Reference | Yes Bandgap |
| Lead Count | 28 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 4 |
| Max 8-Bit Digital Timers | 3 |
| Max ADC Resolution | 12 Bits |
| Max CPU Speed | 64 МГц |
| Max DAC Resolution | 8 Bits |
| Max PWM outputs | 6 including complementary |
| Количество компараторов | 2 |
| Number of DACs | 1 |
| Numerically Controlled Oscillator | 3 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 16 Bits |
| Peripheral Pin Select / Pin Muxing | Yes |
| Pin count | 28 |
| Размер памяти программ | 128 KB |
| SPI | 2 |
| SRAM | 8192 Bytes |
| Signal Measurement Timer | 1 |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 5 |
| Zero Cross detect | Yes |
Серия: PIC18F27Q43 (15)
PIC18F27Q43TI/ML, PIC18F27Q43T I/ML
