Datasheet Texas Instruments OPA2991IDGKR — Даташит
| Серия | OPA2991 |
| Модель | OPA2991IDGKR |
40 В, двухканальный, 4,5 МГц, вход/выход rail-to-rail, низкое напряжение смещения, малошумящий операционный усилитель 8-VSSOP -40 to 125
Datasheet
| 32 предложений от 11 поставщиков Operational Amplifiers - Op Amps 40-V, dual-channel, 4.5-MHz, rail-to-rail input/output, low-offset-voltage, low-noise op amp | |||
| OPA2991IDGKR Texas Instruments | от 21 ₽ | ||
| OPA2991IDGKR Texas Instruments | 96 ₽ | ||
| OPA2991IDGKR | от 205 ₽ | ||
| OPA2991IDGKR Texas Instruments | от 228 ₽ | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | 26UT |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | 0.97 |
| Pitch (мм) | 0.65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Approx. price | .574 | 1ku US$ |
| Архитектура | CMOS |
| CMRR(Min) | 109 дБ |
| CMRR(Typ) | 130 дБ |
| Основные особенности | EMI Hardened,High Cload Drive,MUX Friendly,Shutdown,Small Size |
| GBW(Typ) | 4.5 МГц |
| Input bias current(Typ) | 10 pA |
| Input common mode headroom (to negative supply)(Typ) | -0.1 В |
| Input common mode headroom (to positive supply)(Typ) | 0.1 В |
| Iq per channel(Max) | 0.685 мА |
| Iq per channel(Typ) | 0.56 мА |
| Number of channels | 2 |
| Offset drift(Typ) | 0.3 uV/C |
| Operating temperature range | -40 to 125 C |
| Output current(Typ) | 75 мА |
| Output swing headroom (to negative supply)(Typ) | 0.025 В |
| Output swing headroom (to positive supply)(Typ) | -0.025 В |
| Package Group | SOIC|8,SOT-23-THIN|8,TSSOP|8,VSSOP|8,WSON|8,X2QFN|10 |
| Package size: mm2:W x L | 8SOIC: 19 mm2: 3.91 x 4.9 (SOIC|8),8SOT-23-THIN: 8 mm2: 2.8 x 2.9 (SOT-23-THIN|8),8TSSOP: 19 mm2: 6.4 x 3 (TSSOP|8),8VSSOP: 15 mm2: 4.9 x 3 (VSSOP|8),8WSON: 4 mm2: 2 x 2 (WSON|8),10X2QFN: 3 mm2: 2 x 1.5 (X2QFN|10) PKG |
| Rail-to-rail | In,Out |
| Rating | Catalog |
| Slew rate(Typ) | 21 V/us |
| Total supply voltage(Max) | 40 +5V=5, +/-5V=10 |
| Total supply voltage(Min) | 2.7 +5V=5, +/-5V=10 |
| Vn at 1 kHz(Typ) | 10.8 нВ/rtГц |
| Vos (offset voltage @ 25 C)(Max) | 0.75 мВ |
| Бессвинцовая технология (Pb Free) | Да |
Серия: OPA2991 (6)
- OPA2991IDDFR OPA2991IDGKR OPA2991IDR OPA2991IDSGR OPA2991IPWR OPA2991SIRUGR
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
