Datasheet Texas Instruments OPA991IDBVR — Даташит
| Серия | OPA991 |
| Модель | OPA991IDBVR |
40 В, один 4,5 МГц, вход/выход rail-to-rail, низкое напряжение смещения, малошумящий операционный усилитель 5-SOT-23 -40 to 125
Datasheet
Купить OPA991IDBVR на РадиоЛоцман.Цены — от 16 до 340 ₽51 предложений от 17 поставщиков , 40-V, single 4.5MHz, rail-to-rail input/output, low-offset-voltage, low-noise op amp | |||
| OPA991IDBVR Texas Instruments | 30 ₽ | ||
| OPA991IDBVR Texas Instruments | от 119 ₽ | ||
| OPA991IDBVR Texas Instruments | 340 ₽ | ||
| OPA991IDBVR Texas Instruments | по запросу | ||
| Pin | 5 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | O91V |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | 0.95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| Approx. price | .384 | 1ku US$ |
| Архитектура | CMOS |
| CMRR(Min) | 109 дБ |
| CMRR(Typ) | 130 дБ |
| Основные особенности | EMI Hardened,High Cload Drive,MUX Friendly,Shutdown,Small Size |
| GBW(Typ) | 4.5 МГц |
| Input bias current(Typ) | 10 pA |
| Input common mode headroom (to negative supply)(Typ) | -0.1 В |
| Input common mode headroom (to positive supply)(Typ) | 0.1 В |
| Iq per channel(Max) | 0.685 мА |
| Iq per channel(Typ) | 0.56 мА |
| Number of channels | 1 |
| Offset drift(Typ) | 0.3 uV/C |
| Operating temperature range | -40 to 125 C |
| Output current(Typ) | 75 мА |
| Output swing headroom (to negative supply)(Typ) | 0.025 В |
| Output swing headroom (to positive supply)(Typ) | -0.025 В |
| Package Group | SC70|5,SOT-23|5,SOT-23|6 |
| Package size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2 (SC70|5),5SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|5),6SOT-23: 5 mm2: 1.6 x 2.9 (SOT-23|6) PKG |
| Rail-to-rail | In,Out |
| Rating | Catalog |
| Slew rate(Typ) | 21 V/us |
| Total supply voltage(Max) | 40 +5V=5, +/-5V=10 |
| Total supply voltage(Min) | 2.7 +5V=5, +/-5V=10 |
| Vn at 1 kHz(Typ) | 10.8 нВ/rtГц |
| Vos (offset voltage @ 25 C)(Max) | 0.75 мВ |
| Бессвинцовая технология (Pb Free) | Да |
Серия: OPA991 (3)
- OPA991IDBVR OPA991IDCKR OPA991SIDBVR
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
