Datasheet Toshiba TLX9188 — Даташит
| Производитель | Toshiba |
| Серия | TLX9188 |
| Модель | TLX9188 |
Оптопара (выход на фототранзистор)
Datasheet TLX9188
PDF, 613 Кб, Язык: анг., Файл опубликован: сен 2021, Страниц: 8
TOSHIBA Photocoupler IRLED & Photo-Transistor
|  Купить TLX9188 на РадиоЛоцман.Цены — от 125 до 325 ₽ 18 предложений от 5 поставщиков Оптопары с Транзисторным Выходом | |||
| TLX9188(GBTPL,F | от 125 ₽ | ||
| TLX9188(GBTPL,F Toshiba | от 305 ₽ | ||
| TLX9188(GBTPL,F Toshiba | от 320 ₽ | ||
| TLX9188(GBTPL,F | по запросу | ||
| Количество выводов | 4 |
| Код корпуса производителя | 4pin SO6 |
| Способ монтажа | Surface Mount |
| Ширина×Длина×Высота | 3.7×7.0×2.1 мм |
| Application Scope | Various Controllers / Signal transmission between different circuit potential / HEV(Hybrid Electric Vehicle) and EV(Electric Vehicle) Applications |
| Collector Current | 0.05 A |
| Collector Emitter Saturation Voltage (Max) | 0.4 В |
| Collector-emitter voltage | 200 В |
| Current Transfer Ratio (Max) [IF=5mA VCE=5V rank=GB] | 600 % |
| Current Transfer Ratio (Min) [IF=5mA VCE=5V rank=GB] | 100 % |
| Description | TLX9188 consists of phototransistors optically coupled to an infrared LED. TLX9188 is housed in the very small and thin SO6(4pin) package and that guarantees high temperature operation(Ta=125 °C max). With the high breakdown voltage between the collector and emitter (VCEO=200 V), TLX9188 is suitable for use in battery management system. |
| Основные особенности | 2.3mm low-profile package / High V_CEO |
| Forward Current | 0.03 A |
| Function | High VCEO |
| Input type | DC |
| Isolation voltage BVs @1minute (Min) [t=60sec] | 3750 Vrms |
| Number of Circuits | 1 |
| Рабочий диапазон температур | от -40 до 125 °C |
- Semiconductor > Isolators/Solid State Relays
