Datasheet Texas Instruments TLV9054IDR — Даташит
| Серия | TLV9054 |
| Модель | TLV9054IDR |
Четырехканальный операционный усилитель 5 МГц, 15 В/мкс с высокой скоростью нарастания выходного напряжения, RRIO 14-SOIC -40 to 125
Datasheet
Купить TLV9054IDR на РадиоЛоцман.Цены — от 13 до 142 ₽34 предложений от 13 поставщиков PWR MGMT LINEAR REGULATOR. CMOS Amplifier 1 Circuit Rail-to-Rail 14-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps | |||
| TLV9054IDR Texas Instruments | 37 ₽ | ||
| TLV9054IDR Texas Instruments | 69 ₽ | ||
| TLV9054IDR Texas Instruments | от 92 ₽ | ||
| TLV9054IDR Texas Instruments | 96 ₽ | ||
| Pin | 14 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | TLV9054D |
| Width (мм) | 3.91 |
| Length (мм) | 8.65 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Approx. price | .334 | 1ku US$ |
| Архитектура | CMOS |
| CMRR(Typ) | 96 дБ |
| Основные особенности | Cost Optimized,EMI Hardened,Shutdown,Small Size |
| GBW(Typ) | 5 МГц |
| Input bias current(Typ) | 2 pA |
| Input common mode headroom (to negative supply)(Typ) | -0.1 В |
| Input common mode headroom (to positive supply)(Typ) | 0.1 В |
| Iq per channel(Max) | 0.45 мА |
| Iq per channel(Typ) | 0.33 мА |
| Number of channels | 4 |
| Offset drift(Typ) | 0.5 uV/C |
| Operating temperature range | -40 to 125 C |
| Output current(Typ) | 50 мА |
| Output swing headroom (to negative supply)(Typ) | 0.03 В |
| Output swing headroom (to positive supply)(Typ) | -0.03 В |
| Package Group | QFN|14,SOIC|14,TSSOP|14,WQFN|16 |
| Package size: mm2:W x L | 14QFN: 4 mm2: 2 x 2 (QFN|14),14SOIC: 52 mm2: 6 x 8.65 (SOIC|14),14TSSOP: 32 mm2: 6.4 x 5 (TSSOP|14),16WQFN: 9 mm2: 3 x 3 (WQFN|16) PKG |
| Rail-to-rail | In,Out |
| Rating | Catalog |
| Slew rate(Typ) | 15 V/us |
| Total supply voltage(Max) | 5.5 +5V=5, +/-5V=10 |
| Total supply voltage(Min) | 1.8 +5V=5, +/-5V=10 |
| Vn at 1 kHz(Typ) | 20 нВ/rtГц |
| Vos (offset voltage @ 25 C)(Max) | 1.6 мВ |
| Бессвинцовая технология (Pb Free) | Да |
Серия: TLV9054 (5)
- TLV9054IDR TLV9054IPWR TLV9054IRTER TLV9054IRUCR TLV9054SIRTER
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > General-purpose op amps
