Datasheet HGTG20N60A4D - Fairchild Даташит IGBT, TO-247 — Даташит
Наименование модели: HGTG20N60A4D
![]() 28 предложений от 20 поставщиков Биполярные транзисторы с изолированным затвором (IGBT) 600V N-Channel IGBT SMPS Series | |||
HGTG20N60A4D ON Semiconductor | 33 ₽ | ||
HGTG20N60A4D | от 213 ₽ | ||
Транзистор полевой /MOS-FET или IGBT/ HGTG20N60A4D Fairchild | 412 ₽ | ||
HGTG20N60A4D ON Semiconductor | 1 854 ₽ |
Производитель: Fairchild
Описание: IGBT, TO-247
HGTG20N60A4D, HGT4E20N60A4DS
Data Sheet APRIL 2002
600V, SMPS Series N-Channel IGBT with Anti-Parallel Hyperfast Diode
This family of MOS gated high voltage switching devices combine the best features of MOSFETs and bipolar transistors.
These devices have the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. The IGBT used is the development type TA49339. The diode used in anti-parallel is the development type TA49372. These IGBT's are ideal for many high voltage switching applications operating at high frequencies where low conduction losses are essential. These devices have been optimized for high frequency switch mode power supplies. Formerly Developmental Type TA49341.
Features
- Тип транзистора: IGBT
- DC Collector Current: 70 А
- Collector Emitter Voltage Vces: 2.7 В
- Power Dissipation Max: 290 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Operating Temperature Range: -55°C to +150°C
- Корпус транзистора: TO-247
- Количество выводов: 3
- SVHC: No SVHC (18-Jun-2010)
- Alternate Case Style: SOT-249
- Current Ic Continuous a Max: 70 А
- Current Temperature: 25°C
- Device Marking: HGTG20N60A4D
- Fall Time Typ: 32 нс
- Fall Time tf: 32 нс
- Количество транзисторов: 1
- Package / Case: TO-247
- Power Dissipation: 290 Вт
- Power Dissipation Pd: 290 Вт
- Pulsed Current Icm: 280 А
- Rise Time: 12 нс
- SVHC (Secondary): Bis (2-ethyl(hexyl)phthalate) (DEHP) (18-Jun-2010)
- Termination Type: Through Hole
- Полярность транзистора: N
- Voltage Vces: 600 В
Дополнительные аксессуары:
- Fischer Elektronik - WLK 5
