Datasheet EV200HAANA - Tyco Даташит Реле,, POWER, SPNO, 500 А — Даташит
Наименование модели: EV200HAANA
Купить EV200HAANA на РадиоЛоцман.Цены — от 3 010 до 52 546 ₽ 19 предложений от 13 поставщиков KILOVAC - TE CONNECTIVITY - EV200HAANA - Контактор, 500 А, Панель, 900 В DC, SPST-NO, 1-полюсный | |||
EV200HAANA TE Connectivity | 3 010 ₽ | ||
EV200HAANA TE Connectivity | 3 536 ₽ | ||
EV200HAANA Tyco | 30 821 ₽ | ||
EV200HAANA | от 52 218 ₽ |
Производитель: Tyco
Описание: Реле, POWER, SPNO, 500 А
12-900Vdc
KILOVAC EV200 - 200/250 Amps ("Czonka III")
Make & Break Load Switching
Features: · Low Cost - lowest price sealed relay in the industry with its contact rating · Highest contact rating for its size - 200/ 250 A carry, 2,000 A interrupt at 320 Vdc.
· Optional Auxillary Contact - Easy monitoring of power contact position · Built-In Coil Economizer - Only 1.7 W hold power @ 12 Vdc making it ideal for battery powered systems. Models are available requiring external coil economizer for large volume applications · US and Canadian UL Recognized - UL File No. E208033 · CE Marked for EC Applications · AIAG QS9000, Design, Built & Approved · Hermetically Sealed - Intrinsically safe, operates in explosive & harsh environments Features: like salt, moisture, dust with no oxidation or contamination of coils or contacts providing stable contact resistance over years of use, including long periods of non-operation · Small & Lightweight - smallest sealed relay in the industry with its cur
- Тип реле: Power
- Contact Current Max: 500 А
- Contact Configuration: SPST N/O
- Coil Type: DC Coil
- Coil Current: 3.8 А
- Relay Mounting: Panel
- Внешняя длина / высота: 55.81 мм
- Внешняя ширина: 80.48 мм
- Max Contact Current DC: 250 А
- Max Operating Temperature: 85°C
- Min Temperature Operating: -40°C
- Mounting Type: Panel
- No. of Poles: 1
- Series: EV200
- Approval Bodies: CE Marked
- Approval Category: UL Recognised
- Contact Style: 1 form A
- Current Rating: 200 А
- Dielectric Strength, VDC: 2200 В AC
- Fixing Centres: 68.28 мм
- Insulation Resistance: 100 MOhm
- Max Coil Voltage: 36 В DC
- Max Current Limit: 500 А
- Min Coil Voltage: 9 В DC
- Must Actuate Voltage: 9 В
- Must Release Voltage: 6 В
- Operating Time: 15 мс
- Release Time: 12 мс
- Вес: 425 г
