Datasheet G2A-432A-DC24 - Omron Даташит Реле,, 4PDT, 24 В DC — Даташит
Omron G2A-432A-DC24
Наименование модели: G2A-432A-DC24
Промышленные/Универсальные Реле, Electromechanical Relay 24VDC 530Ω 3A 4PDT (28.5x21.5x42.5)mm Socket Power Relay
G2A-432A-DC24
Omron
1 750 ₽
G2A-432A-DC24
Omron
2 796 ₽
G2A-432A-DC24
Omron
2 840 ₽
МосЧип
G2A-432A-DC24
Omron
Производитель: Omron
Описание: Реле, 4PDT, 24 В DC
data sheetСкачать Data Sheet
Power Relay
G2A
Highly Reliable, 4-pole Miniature Relay Ideal for Sequence Control
· Card lift-off employed for greater life and stable quality.
· Long endurance and stable quality are assured by card lift-off system. · Mounting interchangeability with MY-series Relays. · Operation indicator mechanism incorporated for at-a-glance monitoring of ON/OFF operation. In addition, a built-in operation indicator model is also included in this Relay Series.
Ordering Information
  • Тип реле: Power
  • Nom Coil Voltage DC: 24 В
  • Contact Current Max: 3 А
  • Contact Voltage AC Nom: 110 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 530 Ом
  • Contact Configuration: 4PDT
  • Coil Type: DC Coil
  • Coil Current: 45 мА
  • Nom Operating Power: 1.1 Вт
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 42.5 мм
  • Внешняя ширина: 28.5 мм
  • External Depth: 21.5 мм
  • Max Contact Voltage AC: 120 В
  • Max Contact Voltage DC: 30 В
  • Max Operating Temperature: 40°C
  • Min Temperature Operating: -10°C
  • Mounting Type: Plug-In
  • No. of Poles: 4
  • Series: G2 А
  • Coil Operating Lower Percent Limit: 10%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: AgPd
  • Contact Plating: AgAu
  • Contact Resistance: 100 MOhm
  • Current Rating: 3 А
  • Dielectric Voltage Coil to Contact: 1500 В AC
  • Dielectric Voltage Contact to Contact: 1500 В AC
  • Inductive Current Rating AC: 0.2 А
  • Inductive Current Rating DC: 0.3 А
  • Insulation Resistance: 100 MOhm
  • Max Resistive Current Rating: 0.5 А
  • No. of Electrical Operations: 5000000
Дополнительные аксессуары:
  • Omron - PYF14AE
G2A432ADC24, G2A 432A DC24
На английском языке: Datasheet G2A-432A-DC24 - Omron RELAY, 4PDT, 24 V DC
