Datasheet IRG4BC20FD-SPBF - International Rectifier Даташит IGBT, D2-PAK — Даташит
International Rectifier IRG4BC20FD-SPBF
Наименование модели: IRG4BC20FD-SPBF
Транзистор IGBT, IGBT N-CH W/DIODE 600V 16A D2PAK
IRG4BC20FD-SPBF
209 ₽
Hi-Tech Circuit Group
IRG4BC20FD-SPBF
Infineon
TradeElectronics
IRG4BC20FD-SPBF
SUV System
IRG4BC20FD-SPBF
Описание: IGBT, D2-PAK
data sheetСкачать Data Sheet
PD -95965
IRG4BC20FD-SPbF
INSULATED GATE BIPOLAR TRANSISTOR WITH ULTRAFAST SOFT RECOVERY DIODE
Features
· Fast: Optimized for medium operating frequencies ( 1-5 kHz in hard switching, >20 kHz in resonant mode).
· Generation 4 IGBT design provides tighter parameter distribution and higher efficiency than Generation 3 · IGBT co-packaged with HEXFREDTM ultrafast, ultra-soft-recovery anti-parallel diodes for use in bridge configurations · Industry standard D2Pak package · Lead-Free · Generation 4 IGBTs offer highest efficiencies available · IGBTs optimized for specific application conditions · HEXFRED diodes optimized for performance with IGBTs . Minimized recovery characteristics require less/no snubbing · Designed to be a "drop-in" replacement for equivalent industry-standard Generation 3 IR IGBTs
  • Тип транзистора: IGBT
  • Max Voltage Vce Sat: 1.66 В
  • Collector-to-Emitter Breakdown Voltage: 600 В
  • Корпус транзистора: TO-263 (D2-PAK)
  • Корпус: TO-263 (D2-PAK)
  • Current Temperature: 25°C
  • Max Current Ic Continuous a: 16 А
  • Max Fall Time: 290 нс
  • Power Dissipation: 60 Вт
  • Power Dissipation Pd: 60 Вт
  • Pulsed Current Icm: 64 А
  • Rise Time: 22 нс
  • SMD Marking: IRG4BC20FDS
  • Termination Type: SMD
  • Полярность транзистора: N
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
  • Fischer Elektronik - WLPG 02
IRG4BC20FDSPBF, IRG4BC20FD SPBF
На английском языке: Datasheet IRG4BC20FD-SPBF - International Rectifier IGBT, D2-PAK
