Datasheet DS1E-S-DC12V - Panasonic Даташит PCB Реле, CONTACTS SPDT — Даташит
Наименование модели: DS1E-S-DC12V
![]() 35 предложений от 18 поставщиков Power/Signal Relay, 1 Form C, SPDT, Momentary, 0.017A (Coil), 12VDC (Coil), 200mW (Coil), 2A (Contact), 30VDC (Contact), DC Input, Random, AC-DC... | |||
DS1E-S-DC12V Panasonic | от 6.33 ₽ | ||
DS1E-S-DC12V Matsushita | 327 ₽ | ||
DS1E-S-DC12V Panasonic | от 737 ₽ | ||
DS1E-S-DC12V-TB Panasonic | по запросу |
Производитель: Panasonic
Описание: PCB Реле, CONTACTS SPDT
DS
HIGHLY SENSITIVE 1500 V FCC SURGE BREAKDOWN VOLTAGE MINIATURE RELAY
DS RELAYS
5.
Polarized magnetic circuits realize resistance to shock and vibration High-performance polarized magnetic circuits that utilize the energy of permanent magnets have made it possible to create relays with strong resistance to shock and vibration. 6. DIL terminal array enables use of IC sockets 7. Widening scope of application with multicontact latching In addition to single side stable types, you can take advantage of the memory of functions of convenient 1 coil or 2 coil latching relays.
FEATURES
- Nom Coil Voltage DC: 12 В
- Coil Resistance: 720 Ом
- Contact Configuration: SPDT
- Внешняя длина / высота: 9.8 мм
- Внешняя ширина: 15 мм
- External Depth: 9.9 мм
- Max Contact Current AC: 2 А
- Max Contact Current DC: 2 А
- Max Contact Voltage AC: 250 В
- Max Contact Voltage DC: 220 В
- Mounting Type: PCB
- No. of Poles: 1
- Series: DS
DS1ESDC12V, DS1E S DC12V
