Datasheet DSP1A-DC24V - Panasonic Даташит Реле, SPST 24 В DC — Даташит
Наименование модели: DSP1A-DC24V
![]() 24 предложений от 13 поставщиков Реле Мощности, DSP Series 8A SPST 24V Through Hole Miniature Single Side Stable Power Relay | |||
DSP1A-DC24V-F Panasonic | от 71 ₽ | ||
DSP1A-DC24V Panasonic | по запросу | ||
DSP1A-DC24V-F Panasonic | по запросу | ||
DSP1a-DC24V-AGP2004 Nais | по запросу |
Производитель: Panasonic
Описание: Реле, SPST 24 В DC
DS-P
8 A MINIATURE POWER RELAY IN DS RELAY SERIES
3.
High sensitivity Using the same type of high-performance polar magnetic circuits as DS relays, by matching the spring load to the magnetic force of attraction, greater sensitivity has been achieved. The resultant pick up sensitivity of about 190 mW makes possible direct driving of transistors and chips. 4. High breakdown voltage Breakdown voltage has been raised by keeping the coil and contacts separate.
Between contact and coil 3,000 Vrms for 1 min. 5,000 V surge breakdown voltage Conforms with FCC Part 68 Between contacts 1,000 Vrms for 1 min. 1,500 V surge breakdown voltage
DS-P RELAYS
- Тип реле: Miniature
- Nom Coil Voltage DC: 24 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1.92 кОм
- Contact Configuration: SPST
- Coil Type: DC Coil, Monostable
- Coil Current: 12.5 мА
- Nom Operating Power: 300 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 10.5 мм
- Внешняя ширина: 20.2 мм
- External Depth: 11 мм
- Max Contact Current AC: 8 А
- Max Contact Current DC: 8 А
- Max Contact Voltage AC: 250 В
- Max Contact Voltage DC: 30 В
- Max Operating Temperature: 65°C
- Min Temperature Operating: -40°C
- Mounting Type: PCB
- No. of Poles: 1
- Series: DS
- Approval Bodies: CSA, TUV
- Approval Category: UL Recognised
- Contact Material: Gold flash over silver alloy
- Contact Resistance: 30 MOhm
- DC Coil Power: 300 мВт
- Max Switch Power: 150 Вт
- Max Switch Voltage: 30 В DC
- Max Switching Current AC: 8 А
- Max Switching Current DC: 5 А
- Max Switching Power: 2000VA
- Max Switching Voltage AC / DC: 250 В AC
- Operating Time: 10 мс
- Release Time: 10 мс
Дополнительные аксессуары:
- Tyco - V23154-Z1001
DSP1ADC24V, DSP1A DC24V
