Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet DSP2A-12V - Panasonic Даташит Реле, DPNO, 12 В — Даташит
Panasonic DSP2A-12V
Наименование модели: DSP2A-12V
11 предложений от 7 поставщиков
Универсальное реле, серия DSP, силовое, без защелки, DPST-NO, 12В DC, 5А
DSP2A-12V
Panasonic
444 ₽
DSP2A-12V
Panasonic
от 1 292 ₽
LifeElectronics
DSP2A-12V-R
Panasonic
DSP2A-12V
Panasonic
Решения для систем охлаждения
Производитель: Panasonic
Описание: Реле, DPNO, 12 В
data sheetСкачать Data Sheet
DS-P
8 A MINIATURE POWER RELAY IN DS RELAY SERIES
3.
High sensitivity Using the same type of highperformance polar magnetic circuits as DS relays, by matching the spring load to the magnetic force of attraction, greater sensitivity has been achieved. The resultant pick up sensitivity of about 190 mW makes possible direct driving of transistors and chips. 4. High breakdown voltage Breakdown voltage has been raised by keeping the coil and contacts separate.
Between contact and coil 3,000 Vrms for 1 min. 5,000 V surge breakdown voltage Conforms with FCC Part 68 Between contacts 1,000 Vrms for 1 min. 1,500 V surge breakdown voltage
DS-P RELAYS
  • Тип реле: Miniature
  • Nom Coil Voltage DC: 12 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 480 Ом
  • Contact Configuration: DPNO
  • Coil Type: DC Coil, Monostable
  • Coil Current: 25 мА
  • Nom Operating Power: 300 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 20.2 мм
  • Внешняя ширина: 9.3 мм
  • External Depth: 11 мм
  • Max Contact Current AC: 5 А
  • Max Contact Current DC: 5 А
  • Max Contact Voltage AC: 250 В
  • Max Contact Voltage DC: 30 В
  • Max Operating Temperature: 100В°C
  • Min Temperature Operating: -40В°C
  • Mounting Type: PCB
  • No. of Poles: 2
  • Series: DS
  • Approval Bodies: UL, CSA
  • Contact Material:
  • Contact Resistance: 10 MOhm
  • DC Coil Power: 300 мВт
  • IP Rating: 67
  • Insulation Resistance: 1000 MOhm
  • Max Switching Power: 380VA
  • Release Time: 4 мс
  • Вес: 4.3 г
Дополнительные аксессуары:
  • Panasonic - DSP2A-PSL2
DSP2A12V, DSP2A 12V
На английском языке: Datasheet DSP2A-12V - Panasonic RELAY, DPNO, 12 V
