Datasheet DILM65 (230V 50HZ,240V 60HZ) - Moeller Даташит CONTACTOR, 65 А — Даташит
Наименование модели: DILM65 (230V 50HZ,240V 60HZ)
![]() 11 предложений от 5 поставщиков Coil for contactors; 230VAC; DILM40,DILM50,DILM65,DILM72 | |||
DILM65-XSP(230V50HZ,240V60HZ) | 2 235 ₽ | ||
DILM65-XSP(230V50HZ,240V60HZ) Eaton | от 7 157 ₽ | ||
DILM65-EA(230V50HZ,240V60HZ) | от 38 550 ₽ | ||
DILM65(230V50HZ.240V60HZ) Eaton | 42 798 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 65 А
Type: DILM65(230V50HZ,240V60HZ) Article No.: 277894
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 65 20 30 35 7 12 17 72 DILM150-XHI(V).. DILM1000-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 115 мм
- Внешняя ширина: 55 мм
- External Depth: 147 мм
- Max Contact Current AC: 65 А
- Max Contact Voltage AC: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Operating Frequency: 60Hz
- Max Coil Voltage: 240 В AC
- Max Main Contact Current AC3: 65 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 230 В AC
- Power Rating: 30kW
DILM65 (230V 50HZ240V 60HZ), DILM65 (230V 50HZ 240V 60HZ)
