Datasheet DILM65(RDC24) - Moeller Даташит CONTACTOR, 65 А — Даташит
Наименование модели: DILM65(RDC24)
![]() 15 предложений от 9 поставщиков , The DILM65(RDC24) from Eaton Moeller is a three pole contactor with normally open(N/O) contacts. This smart and compact design device... | |||
DILM65-XSP(RDC24) | 10 462 ₽ | ||
DILM65(RDC24) Moeller | 23 868 ₽ | ||
DILM65-EA(RDC24) | от 55 302 ₽ | ||
DILM65-EA(RDC24) Eaton | от 59 591 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 65 А
Type: DILM65(RDC24) Article No.: 277908
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 65 20 30 35 7 12 17 72 DILM150-XHI(V).. DILM1000-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Nom Coil Voltage DC: 24 В
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 115 мм
- Внешняя ширина: 55 мм
- External Depth: 147 мм
- Max Contact Current AC: 65 А
- Max Contact Voltage AC: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Voltage: 24 В DC
- Max Main Contact Current AC3: 65 А
- Power Rating: 30kW
