Datasheet DILM80(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, 3 POLE, 37KW — Даташит
Moeller DILM80(230V50HZ,240V60HZ)
Наименование модели: DILM80(230V50HZ,240V60HZ)
14 предложений от 8 поставщиков
Контактор, DIN-рейка, Панель, 690 В AC, 3PST-NO, 3-полюсный, 37 кВт
Cooper Bussmann
12 499 ₽
Moeller
18 427 ₽
Зенер
Россия и страны ТС
DILM80-EA(230V50HZ,240V60HZ)
от 48 954 ₽
Eaton Cutler Hammer
от 50 801 ₽
Производитель: Moeller
Описание: CONTACTOR, 3 POLE, 37KW
data sheetСкачать Data Sheet
Type: DILM80(230V50HZ,240V60HZ) Article No.: 239402 Sales text Contactor,37kW/400V,AC operated
Ordering information Connection technique Description Description Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 220 V 230 V AC-3 380 V 400 V AC-3 660 V 690 V AC-4 220 V 230 V AC-4 380 V 400 V AC-4 660 V 690 V Conventional free air thermal current I th = I e AC-1 at 60 °C Open Contacts Can be combined with auxiliary contact DILM150-XHI(V).. DILM1000-XHI(V).. Ith = Ie A 90 P P P P P P kW kW kW kW kW kW 25 37 63 12 20 26 Ie A 80 Screw terminals 3 pole Springloaded terminals on the auxiliary and control circuit terminals
1
Actuating voltage Contact sequence
230 V 50 Hz, 240 V 60 Hz
  • Тип реле: Contactor
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 170 мм
  • Внешняя ширина: 90 мм
  • External Depth: 176 мм
  • Max Contact Current AC: 80 А
  • Max Contact Voltage AC: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP Rating: 00
  • Insulation Voltage: 690 В AC
  • Max Coil Voltage: 240 В AC
  • Max Main Contact Current AC3: 80 А
  • Power Rating: 37kW
DILM80(230V50HZ240V60HZ), DILM80(230V50HZ 240V60HZ)
На английском языке: Datasheet DILM80(230V50HZ,240V60HZ) - Moeller CONTACTOR, 3 POLE, 37KW
