Заказные клавиатуры Accord по вашему ТЗ
Datasheet DILM9-10(24VDC) - Moeller Даташит CONTACTOR, 4KW, WITH 1NO AUX — Даташит
Moeller DILM9-10(24VDC)
Наименование модели: DILM9-10(24VDC)
Производитель: Moeller
Описание: CONTACTOR, 4KW, WITH 1NO AUX
data sheetСкачать Data Sheet
Type: DILM9-10(24VDC) Article No.: 276705
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 9 2.5 4 4.5 1.5 2.5 3.6 20 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Nom Coil Voltage DC: 24 В
  • Внешняя длина / высота: 68 мм
  • Внешняя ширина: 45 мм
  • External Depth: 125 мм
  • Max Contact Voltage AC: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Dielectric Voltage Coil to Contact: 400 В AC
  • Dielectric Voltage Contact to Contact: 400 В AC
  • IP Rating: 20
  • Max Coil Voltage: 24 В DC
  • Max Main Contact Current AC1: 20 А
  • Max Main Contact Current AC3: 9 А
  • Power Rating: 4kW
DILM910(24VDC), DILM9 10(24VDC)
На английском языке: Datasheet DILM9-10(24VDC) - Moeller CONTACTOR, 4KW, WITH 1NO AUX
Политика конфиденциальности
