Datasheet DILM150(RAC120) - Moeller Даташит CONTACTOR, 3 POLE, 75KW — Даташит
Moeller DILM150(RAC120)
Наименование модели: DILM150(RAC120)
Контест
DILM150-XSP(RAC120)
8 965 ₽
Элитан
DILM150-22(RAC120)
Eaton
407 451 ₽
АЦП азиатских производителей
Производитель: Moeller
Описание: CONTACTOR, 3 POLE, 75KW
data sheetСкачать Data Sheet
Type: DILM150(RAC120) Article No.: 239587 Sales text Contactor,75kW/400V,AC operated
Ordering information Connection technique Description Description Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 220 V 230 V AC-3 380 V 400 V AC-3 660 V 690 V AC-4 220 V 230 V AC-4 380 V 400 V AC-4 660 V 690 V Conventional free air thermal current I th = I e AC-1 at 60 °C Open Can be combined with auxiliary contact Actuating voltage Contact sequence Ith = Ie A 190 DILM150-XHI(V).. DILM1000-XHI(V).. RAC 120 P P P P P P kW kW kW kW kW kW 48 75 125 20 34 48 Ie A 150 Screw terminals 3 pole Springloaded terminals on the auxiliary and control circuit terminals
Notes concerning the product group
1
Accessories 1 Overload relay 2 Suppressor 3 Auxiliary contact module Further actuating voltages Accessories 278442 281199 277376 277379 281227
  • Тип реле: Contactor
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 170 мм
  • Внешняя ширина: 90 мм
  • External Depth: 176 мм
  • Contact Current AC Max: 150 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Insulation Voltage: 690 В AC
  • Max Coil Voltage: 120 В AC
  • Max Main Contact Current AC3: 150 А
  • Power Rating: 75kW
На английском языке: Datasheet DILM150(RAC120) - Moeller CONTACTOR, 3 POLE, 75KW
