Datasheet DILM150(RAC240) - Moeller Даташит CONTACTOR, 3 POLE, 75KW — Даташит
Наименование модели: DILM150(RAC240)
Купить DILM150(RAC240) на РадиоЛоцман.Цены — от 8 965 до 160 490 ₽14 предложений от 8 поставщиков Контактор: 3-полюсный; NO x3; 230ВAC; 150А; DILM150; -25÷40°C; 690В | |||
| DILM150(RAC240) Cooper Bussmann | 28 160 ₽ | ||
| DILM150(RAC240) Moeller | 41 119 ₽ | ||
| DILM150(RAC240) Eaton Cutler Hammer | от 124 224 ₽ | ||
| DILM150(RAC240) Eaton | 160 490 ₽ | ||
Производитель: Moeller
Описание: CONTACTOR, 3 POLE, 75KW
Type: DILM150(RAC240) Article No.: 239588 Sales text Contactor,75kW/400V,AC operated
Ordering information Connection technique Description Description Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 220 V 230 V AC-3 380 V 400 V AC-3 660 V 690 V AC-4 220 V 230 V AC-4 380 V 400 V AC-4 660 V 690 V Conventional free air thermal current I th = I e AC-1 at 60 °C Open Contacts Can be combined with auxiliary contact DILM150-XHI(V).. DILM1000-XHI(V).. Ith = Ie A 160 P P P P P P kW kW kW kW kW kW 48 75 96 20 33 48 Ie A 150 Screw terminals 3 pole Springloaded terminals on the auxiliary and control circuit terminals
1
Actuating voltage Contact sequence
RAC 240
- Тип реле: Contactor
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 170 мм
- Внешняя ширина: 90 мм
- External Depth: 176 мм
- Contact Current AC Max: 150 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Voltage: 240 В AC
- Max Main Contact Current AC3: 150 А
- Power Rating: 75kW
