Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet DILM17-10(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, 7.5KW, WITH 1NO AUX — Даташит
Moeller DILM17-10(230V50HZ,240V60HZ)
Наименование модели: DILM17-10(230V50HZ,240V60HZ)
Производитель: Moeller
Описание: CONTACTOR, 7.5KW, WITH 1NO AUX
data sheetСкачать Data Sheet
Type: DILM17-10(230V50HZ,240V60HZ) Article No.: 277004
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 18 5 7.5 11 2.5 4.5 6.5 35 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Внешняя длина / высота: 85 мм
  • Внешняя ширина: 45 мм
  • External Depth: 138 мм
  • Contact Current AC Max: 18 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Coil Frequency Max: 60Hz
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Max Coil Voltage: 240 В AC
  • Max Main Contact Current AC3: 18 А
  • Min Coil Operating Frequency: 50Hz
  • Min Coil Voltage: 230 В AC
  • Power Rating: 7.5kW
DILM1710(230V50HZ,240V60HZ), DILM17 10(230V50HZ,240V60HZ), DILM17-10(230V50HZ240V60HZ), DILM17-10(230V50HZ 240V60HZ)
На английском языке: Datasheet DILM17-10(230V50HZ,240V60HZ) - Moeller CONTACTOR, 7.5KW, WITH 1NO AUX
Политика конфиденциальности
