Datasheet DILM17-10(24V50HZ) - Moeller Даташит CONTACTOR, 7.5KW, WITH 1NO AUX — Даташит
Наименование модели: DILM17-10(24V50HZ)
Купить DILM17 на РадиоЛоцман.Цены — от 2 513 до 39 551 ₽16 предложений от 10 поставщиков , EATON MOELLER DILM17-10(230V50HZ,240V60HZ) Contactor, 690VAC, 3Pole, 3PST-NO, DIN Rail, Panel, 38A, 24V | |||
| DILM17-10(230V50HZ,240V60HZ) Eaton | 2 513 ₽ | ||
| DILM17-10(230V50HZ,240V60HZ) Cooper Bussmann | 2 951 ₽ | ||
| DILM17-11(24V50/60HZ)-PI Eaton | 10 061 ₽ | ||
| DILM17-10[230V50HZ.240V60HZ] | по запросу | ||
Производитель: Moeller
Описание: CONTACTOR, 7.5KW, WITH 1NO AUX
Type: DILM17-10(24V50HZ) Article No.: 276991
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 18 5 7.5 11 2.5 4.5 6.5
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Внешняя длина / высота: 85 мм
- Внешняя ширина: 45 мм
- External Depth: 138 мм
- Contact Current AC Max: 18 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Frequency Max: 50Hz
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Max Coil Voltage: 24 В AC
- Max Main Contact Current AC3: 18 А
- Power Rating: 7.5kW
DILM1710(24V50HZ), DILM17 10(24V50HZ)
