Datasheet DILM25-10(RDC24) - Moeller Даташит CONTACTOR, 11KW, WITH 1NO AUX — Даташит
Moeller DILM25-10(RDC24)
Наименование модели: DILM25-10(RDC24)
Производитель: Moeller
Описание: CONTACTOR, 11KW, WITH 1NO AUX
data sheetСкачать Data Sheet
Type: DILM25-10(RDC24) Article No.: 277146
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 25 7.5 11 14 3.5 6 8.5 40 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Coil Voltage VDC Nom: 24 В
  • Внешняя длина / высота: 85 мм
  • Внешняя ширина: 45 мм
  • External Depth: 138 мм
  • Contact Current AC Max: 25 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Max Coil Voltage: 24 В DC
  • Max Main Contact Current AC3: 25 А
  • Power Rating: 11kW
DILM2510(RDC24), DILM25 10(RDC24)
На английском языке: Datasheet DILM25-10(RDC24) - Moeller CONTACTOR, 11KW, WITH 1NO AUX
Политика конфиденциальности
