Datasheet DILM32-10(RDC24) - Moeller Даташит CONTACTOR, 15KW, WITH 1NO AUX — Даташит
Наименование модели: DILM32-10(RDC24)
Купить DILM32-10(RDC24) на РадиоЛоцман.Цены — от 7 864 до 60 185 ₽14 предложений от 9 поставщиков Контактор: 3-полюсный; NO x3; Вспомогательные контакты: NO; 24ВDC | |||
| DILM32-10(RDC24) Cooper Bussmann | 8 020 ₽ | ||
| DILM32-10(RDC24) | 16 160 ₽ | ||
| DILM32-10(RDC24) Eaton | от 37 086 ₽ | ||
| DILM32-10(RDC24) | 60 185 ₽ | ||
Производитель: Moeller
Описание: CONTACTOR, 15KW, WITH 1NO AUX
Type: DILM32-10(RDC24) Article No.: 277274
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 32 10 15 17 4 7 10 40 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Внешняя длина / высота: 85 мм
- Внешняя ширина: 45 мм
- External Depth: 138 мм
- Contact Current AC Max: 32 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Max Coil Voltage: 24 В DC
- Max Main Contact Current AC3: 32 А
- Power Rating: 15kW
DILM3210(RDC24), DILM32 10(RDC24)
