Datasheet DILM40 (230V 50HZ,240V 60HZ) - Moeller Даташит CONTACTOR, 40 А — Даташит
Наименование модели: DILM40 (230V 50HZ,240V 60HZ)
Купить DILM40 (230V 50HZ на РадиоЛоцман.Цены — от 11 352 до 29 716 ₽17 предложений от 8 поставщиков Контактор 3-полюсный, 230ВAC, 40А, NO x3, DIN,на панель, -25-40°C | |||
| DILM40(230V50HZ,240V60HZ) | 11 352 ₽ | ||
| DILM40-EA(230V50HZ,240V60HZ) Eaton | от 12 517 ₽ | ||
| DILM40-EA(230V50HZ,240V60HZ) | от 23 206 ₽ | ||
| DILM40-EA(230V50HZ,240V60HZ) Eaton | от 23 596 ₽ | ||
Производитель: Moeller
Описание: CONTACTOR, 40 А
Type: DILM40(230V50HZ,240V60HZ) Article No.: 277766
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 40 12.5 18.5 23 5 9 12 50 DILM150-XHI(V).. DILM1000-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 115 мм
- Внешняя ширина: 55 мм
- External Depth: 147 мм
- Contact Current AC Max: 40 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Coil Frequency Max: 60Hz
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Voltage: 240 В AC
- Max Main Contact Current AC3: 40 А
- Min Coil Operating Frequency: 50Hz
- Min Coil Voltage: 230 В AC
- Power Rating: 18.5kW
DILM40 (230V 50HZ240V 60HZ), DILM40 (230V 50HZ 240V 60HZ)
