Datasheet DILM40 (24V 50HZ) - Moeller Даташит CONTACTOR, 40 А — Даташит
Moeller DILM40 (24V 50HZ)
Наименование модели: DILM40 (24V 50HZ)
Контактор силовой 3 полюса, 40А, до 23кВт, 24В, 500мА
Контест
DILM40(24V50HZ)12 861 ₽
Производитель: Moeller
Описание: CONTACTOR, 40 А
data sheetСкачать Data Sheet
Type: DILM40(24V50HZ) Article No.: 277753
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 40 12.5 18.5 23 5 9 12
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 115 мм
  • Внешняя ширина: 55 мм
  • External Depth: 147 мм
  • Contact Current AC Max: 40 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Coil Frequency Max: 50Hz
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Insulation Voltage: 690 В AC
  • Max Coil Voltage: 24 В AC
  • Max Main Contact Current AC3: 40 А
  • Power Rating: 18.5kW
На английском языке: Datasheet DILM40 (24V 50HZ) - Moeller CONTACTOR, 40 A
