Datasheet DILM40(RDC24) - Moeller Даташит CONTACTOR, 40 А — Даташит
Наименование модели: DILM40(RDC24)
![]() 15 предложений от 9 поставщиков Контактор, DIN-рейка, Панель, 690 В AC, 3PST-NO, 3-полюсный, 18.5 кВт | |||
DILM40(RDC24) Eaton | 9 014 ₽ | ||
DILM40(RDC24) Moeller | 12 928 ₽ | ||
DILM40-EA(RDC24) | от 31 772 ₽ | ||
DILM40-EA(RDC24) Eaton Cutler Hammer | от 32 970 ₽ |
Производитель: Moeller
Описание: CONTACTOR, 40 А
Type: DILM40(RDC24) Article No.: 277780
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 40 12.5 18.5 23 5 9 12 50 DILM150-XHI(V).. DILM1000-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Contact Configuration: 3 N/O
- Внешняя длина / высота: 115 мм
- Внешняя ширина: 55 мм
- External Depth: 147 мм
- Contact Current AC Max: 40 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Dielectric Voltage Coil to Contact: 440 В AC
- Dielectric Voltage Contact to Contact: 440 В AC
- IP / NEMA Rating: 00
- Insulation Voltage: 690 В AC
- Max Coil Voltage: 24 В DC
- Max Main Contact Current AC3: 40 А
- Power Rating: 18.5kW
