Datasheet DILM50 (110V 50HZ,120V 60HZ) - Moeller Даташит CONTACTOR, 50 А — Даташит
Moeller DILM50 (110V 50HZ,120V 60HZ)
Наименование модели: DILM50 (110V 50HZ,120V 60HZ)
Контест
DILM50(110V50HZ,120V60HZ)16 993 ₽
Производитель: Moeller
Описание: CONTACTOR, 50 А
data sheetСкачать Data Sheet
Type: DILM50(110V50HZ,120V60HZ) Article No.: 277827
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Ie P P P P P P A kW kW kW kW kW kW 50 15.5 22 30 6 10 14
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open Enclosed Storage °C °C °C -25/60 -25/40 -40/80 Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 115 мм
  • Внешняя ширина: 55 мм
  • External Depth: 147 мм
  • Contact Current AC Max: 50 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Coil Frequency Max: 60Hz
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Insulation Voltage: 690 В AC
  • Max Coil Voltage: 120 В AC
  • Max Main Contact Current AC3: 50 А
  • Min Coil Operating Frequency: 50Hz
  • Min Coil Voltage: 110 В AC
  • Power Rating: 22kW
DILM50 (110V 50HZ120V 60HZ), DILM50 (110V 50HZ 120V 60HZ)
На английском языке: Datasheet DILM50 (110V 50HZ,120V 60HZ) - Moeller CONTACTOR, 50 A
