Datasheet DILM50(RDC24) - Moeller Даташит CONTACTOR, 50 А — Даташит
Moeller DILM50(RDC24)
Наименование модели: DILM50(RDC24)
10 предложений от 5 поставщиков
Контактор: 3-полюсный; NO x3; 24ВDC; 50А; DIN,на панель; DILM50
DILM50(RDC24)
Eaton
11 983 ₽
Контест
DILM50(RDC24)
23 080 ₽
DILM50-EA(RDC24)
Eaton Cutler Hammer
от 44 006 ₽
Зенер
Россия и страны ТС
DILM50-EA(RDC24)
от 47 388 ₽
Производитель: Moeller
Описание: CONTACTOR, 50 А
data sheetСкачать Data Sheet
Type: DILM50(RDC24) Article No.: 277844
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 50 15.5 22 30 6 10 14 60 DILM150-XHI(V).. DILM1000-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 5000 5000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Coil Voltage VDC Nom: 24 В
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 115 мм
  • Внешняя ширина: 55 мм
  • External Depth: 147 мм
  • Contact Current AC Max: 50 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Insulation Voltage: 690 В AC
  • Max Coil Voltage: 24 В DC
  • Max Main Contact Current AC3: 50 А
  • Power Rating: 22kW
На английском языке: Datasheet DILM50(RDC24) - Moeller CONTACTOR, 50 A
