Datasheet DILEM-10(230V50HZ,240V60HZ) - Moeller Даташит CONTACTOR, MINI, 4KW — Даташит
Наименование модели: DILEM-10(230V50HZ,240V60HZ)
![]() 10 предложений от 4 поставщиков Контактор: 3-полюсный; NO x3; Вспомогательные контакты: NO; 8,8А | |||
DILEM-10-C(230V50HZ,240V60HZ) | 3 583 ₽ | ||
DILEM-10-EA(230V50HZ,240V60HZ) | от 5 176 ₽ | ||
DILEM-10-EA(230V50HZ,240V60HZ) Eaton Cutler Hammer | от 5 370 ₽ | ||
DILEM-10-EA(230V50HZ,240V60HZ) Eaton | от 5 577 ₽ |
Производитель: Moeller
Описание: CONTACTOR, MINI, 4KW
Type: DILEM-10(220V50HZ,240V60HZ) Article No.: 051785
Ordering information
Actuating voltage Description Connection technique 380 V 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 220 V 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 380 V 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 660 V 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 220 V 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 380 V 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 660 V 690 V Conventional thermal current I th = I e AC-1 Open Conventional thermal current I th = I e AC-1 Enclosed Contacts M = Make Can be combined with auxiliary contact Ie P P P P P P Ith = Ie Ith = Ie A kW kW kW kW kW kW A A 220V 50 Hz, 240V 60 Hz 3-pole, with auxiliary contacts Screw terminals 8.8 2.2 4 4 1.5 3 3 20 16 1M ...DILEM ...DILE
Contact sequence
Notes concerning the product group
- Тип реле: Contactor
- Contact Configuration: 1 N/O
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Voltage AC Max: 690 В
- Mounting Type: DIN Rail
- No. of Poles: 3
- Series: DILEM
- Approval Bodies: IEC/EN 60947, VDE0660, CSA, UL
- Aux Contact Current Max: 10 А
- Coil Frequency Max: 60Hz
- Coil Operating Frequency Min: 50Hz
- Coil Voltage Max: 240 В
- Coil Voltage Min: 220 В
- Dielectric Voltage Coil to Contact: 300 В AC
- Dielectric Voltage Contact to Contact: 300 В AC
- IP / NEMA Rating: 20
- Insulation Voltage: 690 В AC
- Main Contact Current AC1 Max: 20 А
- Main Contact Current AC3 Max: 9 А
DILEM10(230V50HZ,240V60HZ), DILEM 10(230V50HZ,240V60HZ), DILEM-10(230V50HZ240V60HZ), DILEM-10(230V50HZ 240V60HZ)
