Datasheet DILEM-10-G(24VDC) - Moeller Даташит CONTACTOR, MINI, 4KW — Даташит
Наименование модели: DILEM-10-G(24VDC)
![]() 20 предложений от 12 поставщиков , The DILEM-10G(24VDC) from Eaton Moeller is a three pole mini contactor with normally open (N/O) contacts. DIL E mini contactors... | |||
DILEM-10-G(24VDC) Cooper Bussmann | 1 990 ₽ | ||
DILEM-10-G-EA(24VDC) Eaton Cutler Hammer | от 7 013 ₽ | ||
DILEM-10-G-EA(24VDC) | от 7 338 ₽ | ||
DILEM-10-G-C-24VDC | по запросу |
Производитель: Moeller
Описание: CONTACTOR, MINI, 4KW
Type: DILEM-10-G(24VDC) Article No.: 010213
Ordering information
Description Connection technique Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 220 V 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 380 V 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 660 V 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 220 V 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 380 V 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 660 V 690 V Conventional thermal current I th = I e AC-1 Open Conventional thermal current I th = I e AC-1 Enclosed Contacts M = Make Contacts B = Break Can be combined with auxiliary contact Ie P P P P P P Ith = Ie Ith = Ie A kW kW kW kW kW kW A A 3-pole, with auxiliary contacts Screw terminals 9 2.2 4 4 1.5 3 3 20 16 1M 1B ...DILEM ...DILE
Contact sequence
Note concerning the product
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Voltage AC Max: 690 В
- Mounting Type: DIN Rail
- No. of Poles: 3
- Series: DILEM
- Approval Bodies: IEC/EN 60947, VDE 0660, CSA, UL
- Aux Contact Current Max: 10 А
- Dielectric Voltage Coil to Contact: 300 В AC
- Dielectric Voltage Contact to Contact: 300 В AC
- IP / NEMA Rating: 20
- Insulation Voltage: 690 В AC
- Main Contact Current AC1 Max: 20 А
- Main Contact Current AC3 Max: 9 А
DILEM10G(24VDC), DILEM 10 G(24VDC)
