Datasheet DILER-22(110V50HZ,120V60HZ) - Moeller Даташит Реле, MINI, 2N0/2NC — Даташит
Наименование модели: DILER-22(110V50HZ,120V60HZ)
Купить DILER-22(110V50HZ на РадиоЛоцман.Цены — от 2 585 до 4 014 ₽, Circuit Protection Misc Input Terminal Block | |||
| DILER22(110V50HZ,120V60HZ) Moeller | 2 585 ₽ | ||
| DILER-22-C(110V50HZ,120V60HZ) | 4 014 ₽ | ||
| DILER22(110V50HZ,120V60H | по запросу | ||
Производитель: Moeller
Описание: Реле, MINI, 2N0/2NC
Type: DILER-22(110V50HZ,120V60HZ) Article No.: 051774
Ordering information
Actuating voltage Connection technique Contacts M = Make Contacts B = Break Conventional thermal current Distinctive number and version of combination Ith A 110V 50Hz, 120V 60Hz Screw terminals 2M 2B 10 22 E
Contact sequence
General
- Тип реле: Contactor
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 2 N/O + 2 N/C
- Coil Type: AC Coil
- Nom Operating Power: 200 мВт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Voltage AC Max: 690 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Coil Voltage Max: 120 В
- Coil Voltage Min: 110 В
- Current Rating: 10 А
- Frequency Max: 60Hz
- Frequency Min: 50Hz
- IP / NEMA Rating: IP20
- Insulation Voltage: 690 В AC
- Terminal Type: Screw Terminals
DILER22(110V50HZ,120V60HZ), DILER 22(110V50HZ,120V60HZ), DILER-22(110V50HZ120V60HZ), DILER-22(110V50HZ 120V60HZ)
