Datasheet DILER-22(380V50HZ,440V60HZ) - Moeller Даташит Реле, MINI, 2N0/2NC — Даташит
Moeller DILER-22(380V50HZ,440V60HZ)
Наименование модели: DILER-22(380V50HZ,440V60HZ)
Контест
DILER-22-C(380V50HZ,440V60HZ)4 014 ₽
Производитель: Moeller
Описание: Реле, MINI, 2N0/2NC
data sheetСкачать Data Sheet
Type: DILER-22(380V50HZ,440V60HZ) Article No.: 051778
Ordering information
Actuating voltage Connection technique Contacts M = Make Contacts B = Break Conventional thermal current Distinctive number and version of combination Ith A 380V 50Hz, 440V 60Hz Screw terminals 2M 2B 10 22 E
Contact sequence
General
  • Тип реле: Contactor
  • Coil Voltage VAC Nom: 440 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 415 В
  • Contact Configuration: 2 N/O + 2 N/C
  • Coil Type: AC Coil
  • Nom Operating Power: 200 мВт
  • Relay Mounting: DIN Rail
  • Внешняя длина / высота: 58 мм
  • Внешняя ширина: 45 мм
  • External Depth: 52 мм
  • Contact Voltage AC Max: 690 В
  • Mounting Type: DIN Rail / Panel
  • No.
    of Poles: 4
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Coil Voltage Max: 440 В
  • Coil Voltage Min: 380 В
  • Current Rating: 6 А
  • Frequency Max: 60Hz
  • Frequency Min: 50Hz
  • IP / NEMA Rating: IP20
  • Insulation Voltage: 690 В AC
  • Terminal Type: Screw Terminals
DILER22(380V50HZ,440V60HZ), DILER 22(380V50HZ,440V60HZ), DILER-22(380V50HZ440V60HZ), DILER-22(380V50HZ 440V60HZ)
На английском языке: Datasheet DILER-22(380V50HZ,440V60HZ) - Moeller RELAY, MINI, 2N0/2NC
