Datasheet DILER-31(380V50HZ,440V60HZ) - Moeller Даташит Реле, MINI, 3N0/1NC — Даташит
Наименование модели: DILER-31(380V50HZ,440V60HZ)
Производитель: Moeller
Описание: Реле, MINI, 3N0/1NC
Type: DILER-31(380V50HZ,440V60HZ) Article No.: 051769
Ordering information
Actuating voltage Connection technique Contacts M = Make Contacts B = Break Conventional thermal current Distinctive number and version of combination Ith A 380V 50Hz, 440V 60Hz Screw terminals 3M 1B 10 31 E
Contact sequence
General
- Тип реле: Contactor
- Coil Voltage VAC Nom: 440 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 3 N/O + 1 N/C
- Coil Type: AC Coil
- Nom Operating Power: 200 мВт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Voltage AC Max: 440 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Coil Voltage Max: 440 В
- Coil Voltage Min: 380 В
- Current Rating: 10 А
- Frequency Max: 60Hz
- Frequency Min: 50Hz
- IP / NEMA Rating: IP20
- Insulation Voltage: 690 В AC
- Terminal Type: Screw Terminals
DILER31(380V50HZ,440V60HZ), DILER 31(380V50HZ,440V60HZ), DILER-31(380V50HZ440V60HZ), DILER-31(380V50HZ 440V60HZ)
