Datasheet DILER-31-G(24VDC) - Moeller Даташит Реле, MINI, 3N0/1NC — Даташит
Наименование модели: DILER-31-G(24VDC)
![]() 18 предложений от 10 поставщиков , The DILER-31G(24VDC) is a 4Pole Miniature Control Relay with DC coil, DILER series. 4NO contact configuration. DIL ER relay is... | |||
DILER-31-G(24VDC) Moeller | 3 408 ₽ | ||
DILER-31-G-EA(24VDC) Eaton Cutler Hammer | от 9 788 ₽ | ||
DILER-31-G-EA(24VDC) | от 10 241 ₽ | ||
DILER-31-G-24VDC | по запросу |
Производитель: Moeller
Описание: Реле, MINI, 3N0/1NC
Type: DILER-31-G(24VDC) Article No.: 010157
Ordering information
Connection technique Type of current AC/DC Contacts M = Make Contacts B = Break Rated operational current AC15 220 V 230 V 240 V Conventional thermal current Distinctive number and version of combination Ie Ith A A Screw terminals DC operation 3M 1B 6 10 31 E
Contact sequence
Note concerning the product
- Тип реле: Contactor
- Coil Voltage VAC Nom: 25 В
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 3 N/O + 1 N/C
- Coil Type: DC Coil
- Nom Operating Power: 300 мВт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Current AC Max: 6 А
- Contact Voltage AC Max: 690 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Current Rating: 10 А
- DC Coil Power: 2.6 Вт
- Input Voltage Max: 24 В DC
- Insulation Voltage: 690 В AC
- Terminal Type: Screw Terminals
DILER31G(24VDC), DILER 31 G(24VDC)
