Datasheet DILER-40-G(24VDC) - Moeller Даташит Реле, MINI, 4N0 — Даташит
Наименование модели: DILER-40-G(24VDC)
![]() 17 предложений от 9 поставщиков , The DILER-40G(24VDC) from Eaton Moeller is a contactor with interlocked opposing contacts. It has 4 poles with normally open (N/O)... | |||
DILER-40-G(24VDC) Eaton | 3 422 ₽ | ||
DILER-40-G(24VDC) Cooper Bussmann | 3 899 ₽ | ||
DILER-40-G-EA(24VDC) Eaton | от 10 365 ₽ | ||
DILER-40-G(24VDC) Eaton | 11 758 ₽ |
Производитель: Moeller
Описание: Реле, MINI, 4N0
Type: DILER-40-G(24VDC) Article No.: 010223
Ordering information
Connection technique Type of current AC/DC Contacts M = Make Rated operational current AC15 220 V 230 V 240 V Conventional thermal current Distinctive number and version of combination Ie Ith A A Screw terminals DC operation 4M 6 10 40 E
Contact sequence
Note concerning the product
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 4 N/O
- Coil Type: DC Coil
- Nom Operating Power: 300 мВт
- Relay Mounting: DIN Rail / Surface
- Внешняя длина / высота: 58 мм
- Внешняя ширина: 45 мм
- External Depth: 52 мм
- Contact Current AC Max: 6 А
- Contact Current DC Max: 6 А
- Contact Voltage AC Max: 690 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Current Rating: 6 А
- Insulation Voltage: 690 В AC
DILER40G(24VDC), DILER 40 G(24VDC)
